Amino acid-based squaramides for anion recognition
Eight receptors 1–8 comprising an L-lysine scaffold modified at N- and C-termini with aliphatic alkyl chains and N,N0-alkyl amides, respectively, and bearing squaramide moieties on the amino acid side chain were synthesised by a combination of solid- and solution-phase chemistries ...
See moreEight receptors 1–8 comprising an L-lysine scaffold modified at N- and C-termini with aliphatic alkyl chains and N,N0-alkyl amides, respectively, and bearing squaramide moieties on the amino acid side chain were synthesised by a combination of solid- and solution-phase chemistries and shown to complex various anions in 0.5%H2Oin dimethyl sulfoxide-d6 solution. All of the receptors were found to bind SO22 4 ; Cl2, AcO2 and BzO2 via hydrogen-bond or acid–base interactions with the squaramide protons; however, 1 was found to bind to SO22 4 via hydrogen bonds formed between the anion and both the squaramide and amideNHmoieties. Moreover, modification of both the N- and C-termini of the amino acids with different alkyl substituents had a negligible effect on their anion-binding properties while simultaneously conferring lipophilicities in a range that is optimal for molecules to behave as ‘drug-like’ systems as defined by Lipinski’s rule of five. The results of this study demonstrate the versatility of such amino acid receptors as building blocks in the field of anion recognition.
2015-01-01Publisher
Taylor and FrancisFunding information
ARC DP140100227Licence
This is an Accepted Manuscript of an article published by Taylor & Francis in Supramolecular Chemistryon 2015available online: http://www.tandfonline.com/ 10.1080/10610278.2014.976221Faculty/School
Elmes, R. B. P., & Jolliffe, K. A. (2014). Amino acid-based squaramides for anion recognition. Supramolecular Chemistry, 27(5–6), 321–328. https://doi.org/10.1080/10610278.2014.976221Share
