Tuning the Giant Magnetoelastic Transition in Ba3BiIr2O9 and Ba3BiRu2O9
We have experimentally investigated the effects of pressure on the magnetoelastic transitions associated with the opening of spin-gaps in Ba3BiIr2O9 and Ba3BiRu2O9. For both compounds, reducing the unit cell volume by either external physical and internal chemical pressure was found ...
See moreWe have experimentally investigated the effects of pressure on the magnetoelastic transitions associated with the opening of spin-gaps in Ba3BiIr2O9 and Ba3BiRu2O9. For both compounds, reducing the unit cell volume by either external physical and internal chemical pressure was found to reduce the temperature T ∗ of the transition and, to a lesser extent, the magnitude of the associated negative thermal volume expansion. The results yield the latent heat associated with the transitions, −3.34(3)×102 J mol−1 for Ba3BiIr2O9 and −7.1(5)×102 J mol−1 for Ba3BiRu2O9. The transition in Ba3BiRu2O9 is significantly more robust than in Ba3BiIr2O9, requiring an order of magnitude higher pressures to achieve the same reduction in T∗. The differing responses of the two compounds points to differences between the 4d and 5d metals and hence to the importance of spin-orbit coupling, which is expected to be much stronger in the Ir compound.
2014Source title
Journal of Physics: Condensed MatterVolume
26Publisher
IOP PublishingFunding information
ARC DP110102662Licence
