Manganese metaphosphate Mn(PO3)2 as a high-performance negative electrode material for lithium-ion batteries
Xia, QingboNaeyaert, Pierre J P
Avdeev, Maxim
Schmid, Siegbert A
Liu, Hongwei
Johannessen, B
Ling, Chris D
We report a novel negative conversion electrode material, manganese (II) metaphosphate Mn(PO3)2. This compound can be synthesized by a facile solid-state method, and after carbon-coating delivers an attractively high reversible capacity of 477 mAh/g at 0.1C and 385 mAh/g at 1C. We ...
See moreWe report a novel negative conversion electrode material, manganese (II) metaphosphate Mn(PO3)2. This compound can be synthesized by a facile solid-state method, and after carbon-coating delivers an attractively high reversible capacity of 477 mAh/g at 0.1C and 385 mAh/g at 1C. We investigated the reaction mechanism with a combination of ex situ X-ray absorption spectroscopy, in situ X-ray diffraction, and high-resolution transmission electron microscopy. We observed a direct conversion process by monitoring the first discharge in operando, in which Mn(PO3)2 reacts with Li to give fusiform Mn nanograins a few Ångstroms in width, embedded in a matrix of lithium conducting LiPO3 glass. Due to the fine nanostructures of the conversion products, this conversion reaction is completely reversible.
2020Source title
ChemElectroChemVolume
7Publisher
WileyFunding information
ARC DP170100269Licence
"This is the peer reviewed version of the following article: Q. Xia, P. J. P. Naeyaert, M. Avdeev, S. Schmid, H. Liu, B. Johannessen, C. D. Ling, ChemElectroChem 2020, 7, 2831, which has been published in final form at https://doi.org/10.1002/celc.202000389. This article may be used for non-commercial purposes in accordance with Wiley Terms and Conditions for Use of Self-Archived Versions. This article may not be enhanced, enriched or otherwise transformed into a derivative work, without express permission from Wiley or by statutory rights under applicable legislation. Copyright notices must not be removed, obscured or modified. The article must be linked to Wiley’s version of record on Wiley Online Library and any embedding, framing or otherwise making available the article or pages thereof by third parties from platforms, services and websites other than Wiley Online Library must be prohibited."Faculty/School
