Steric Stabilization of γ-Fe2O3 Superparamagnetic Nanoparticles in a Hydrophobic Ionic Liquid and the Magnetorheological Behavior of the Ferrofluid
Priyananda, PramithAbstract
Hydrophobic ionic liquid ferrofluids (ILFFs) are studied for use in electrospray thrusters for microsatellite propulsion under no atmosphere and in high temperature environments. We synthesized a hydrophobic ILFF by dispersing sterically stabilized γ-Fe2O3 nanoparticles in the ionic ...
See moreHydrophobic ionic liquid ferrofluids (ILFFs) are studied for use in electrospray thrusters for microsatellite propulsion under no atmosphere and in high temperature environments. We synthesized a hydrophobic ILFF by dispersing sterically stabilized γ-Fe2O3 nanoparticles in the ionic liquid EMIM-NTf2. A diblock copolymer, C4-RAFT-AA10-DEAm60, was synthesized to facilitate multipoint bidentate anchoring to the nanoparticle through the acrylic acid block. The DEAm60 layer was incorporated to generate steric repulsion between particles to protect against the aggregation of magnetized particles arising from dipole-dipole attraction. The effect of shearing and variation in the magnetic field strength on the steric repulsion was examined using the DLVO theory. The effect of varying the magnetic field strength and particle concentration on the viscoelastic properties of the ferrofluid was evaluated using rheometry. The viscosity of the ferrofluid increased with the magnetic field strength, indicating the magnetized particles assembled into a structure. The level of straining required to breakdown the structure formed by the magnetized particles increased with the magnetic field strength and particle concentration. The absence of particle interlocking during shearing was indicated by the smooth viscosity vs shear rate traces. The DLVO analysis showed that increasing the magnetic attraction between the particles causes the DEAm60 brush layers on the particles to overlap more, resulting in an increase in the steric repulsion. As overlapping increases osmotic repulsion is caused before progressing to a strong elastic repulsion. The effect of the polymer solubility and particle interaction due to hydrodynamic forces on the steric repulsion were also analyzed.
2018Source title
LangmuirVolume
34Publisher
ACSFunding information
Asian Office of Aerospace R&D (award no. FA2386-16-1-4029)
Licence
Faculty of Science, School of ChemistrySubjects
Physical ChemistryShare
