Dual-functionalisation of fluorophores for the preparation of targeted and selective probes
A key current challenge in biological research is the elucidation of the roles that chemicals and chemical reactions play in cellular function and dysfunction. Of the available cellular imaging techniques, fluorescence imaging offers a balance between sensitivity ...
See moreA key current challenge in biological research is the elucidation of the roles that chemicals and chemical reactions play in cellular function and dysfunction. Of the available cellular imaging techniques, fluorescence imaging offers a balance between sensitivity and resolution, enabling the cost-effective and rapid visualisation of model biological systems. Importantly, the use of responsive fluorescent probes in conjunction with ever-advancing microscopy and flow cytometry techniques enables the visualisation, with high spatiotemporal resolution, of both specific chemical species and chemical reactions in living cells. Ideal responsive fluorescent probes are those that contain a fluorophore tethered to both a sensing unit, to ensure selectivity of response, and a targeting group, to control the sub-cellular localisation of the probe. To date, probes that are both targeted and selective are relatively rare and most localised probes are discovered serendipitously rather than by design. A challenge in this field is therefore the identification of suitable fluorophore scaffolds that can be readily attached to both sensing and targeting groups. Here we review current strategies for dual-functionalisation of fluorophores, highlighting key examples of targeted, responsive probes.
2020Source title
Angewandte Chemie International EditionVolume
59Issue
46Publisher
WileyFunding information
ARC DP180101353Licence
"This is the peer reviewed version of the following article: N. Trinh, K. A. Jolliffe, E. J. New, Angew. Chem. Int. Ed. 2020, 59, 20290.. which has been published in final form at https://onlinelibrary. https://doi.org/10.1002/anie.202007673. This article may be used for non-commercial purposes in accordance with Wiley Terms and Conditions for Use of Self-Archived Versions. This article may not be enhanced, enriched or otherwise transformed into a derivative work, without express permission from Wiley or by statutory rights under applicable legislation. Copyright notices must not be removed, obscured or modified. The article must be linked to Wiley’s version of record on Wiley Online Library and any embedding, framing or otherwise making available the article or pages thereof by third parties from platforms, services and websites other than Wiley Online Library must be prohibited."Faculty/School
