Antifouling Properties of Liquid-Infused Riblets Fabricated by Direct Contactless Microfabrication
The fabrication of riblets and surfaces structured with aligned grooves, by direct
contactless microfabrication (DCM), and the ability of the riblets to function as
lubricant-infused surfaces, is reported. Three types of riblets are fabricated with
features (width, height, and ...
See moreThe fabrication of riblets and surfaces structured with aligned grooves, by direct contactless microfabrication (DCM), and the ability of the riblets to function as lubricant-infused surfaces, is reported. Three types of riblets are fabricated with features (width, height, and period) on the micrometric scale, and with two different UV-crosslinkable coatings. Riblets with width 10 μm, period 40 μm, and height 30 μm show high water repellence as prepared (water contact angle [WCA] 147 ) and, once infused with silicone oil 10 cSt, result in water droplets rolling off the surface at tilt angles of 10 . These riblets are effective at reducing the attachment of marine bacteria, both in the as-prepared and infused form. The DCM process produces structured surfaces over large areas (10 10 cm2) in a few minutes and using inexpensive materials, making mechanically robust surfaces. The DCM process is scalable to the large surface areas required for marine and other applications. The low roll-off angles and the bacterial inhibition results achieved on the riblets indicate that riblets are an up-scalable and nontoxic alternative to more complicated fabricated techniques, with potential as antifouling and drag-reducing coatings.
2021Source title
Advanced Engineering MaterialsVolume
23Publisher
WileyFunding information
ARC FT180100214Licence
Creative Commons Attribution-NonCommercial 4.0Rights statement
This is the peer reviewed version of the following article: Jianbin Zhang, Shangshang Bo, Haiyan Feng, Bo Yu, Qiangliang Yu, Wufang Yang, Xiaowei Pei, Feng Zhou, Imparting Strong Antifouling Properties to the Transparent PVB Coating through the Zwitterionic Compound Condensation, Coatings, 10.3390/coatings11101164, 11, 10, (1164), (2021)., which has been published in final form at https://doi.org/10.1002/adem.202000905. This article may be used for non-commercial purposes in accordance with Wiley Terms and Conditions for Use of Self-Archived Versions.Faculty/School
