Large Effective Slip on Lubricated Surfaces Measured with Colloidal Probe AFM
In this work, we study the interfacial boundary conditions at the interface between two immiscible liquids under laminar flow. We measure the hydrodynamic drainage forces acting on a colloid probe as it approaches a flat and smooth Teflon film coated with silicone oil films, submerged ...
See moreIn this work, we study the interfacial boundary conditions at the interface between two immiscible liquids under laminar flow. We measure the hydrodynamic drainage forces acting on a colloid probe as it approaches a flat and smooth Teflon film coated with silicone oil films, submerged in a sucrose solution, using atomic force microscopy (AFM). On Teflon substrates, silicone oil films of thickness several hundred nm could be stabilized, and we found the effective slip length over these to be of the order of several hundred nanometers and increasing with increasing silicone oil film thickness, as expected. The fitted slip length values weakly increased with increasing shear rates. The high values of effective slip length indicate that lubricant-infused surfaces are likely to reduce drag on length scales that approach the macroscopic.
2020Source title
LangmuirVolume
36Publisher
American Chemical SocietyLicence
Creative Commons Attribution-NonCommercial 4.0Faculty/School
