Selective Endo and Exo Binding of Mono- and Ditopic Ligands to a Rhomboidal Diporphyrin Prism
Copper(I) can preferentially form heteroleptic complexes containing two phosphine and two nitrogen donors due to steric factors. This preference was employed to direct the self-assembly of a porphyrin-faced rhomboidal prism having two parallel tetrakis(4-iminopyridyl)porphyrina- ...
See moreCopper(I) can preferentially form heteroleptic complexes containing two phosphine and two nitrogen donors due to steric factors. This preference was employed to direct the self-assembly of a porphyrin-faced rhomboidal prism having two parallel tetrakis(4-iminopyridyl)porphyrina- tozinc(II) faces linked by eight 1,4-bis(diphenylphosphino)- benzene pillars. The coordination preferences of the CuI ions and geometries of the ligands come together to generate a slipped-cofacial orientation of the porphyrinatozinc(II) faces. This orientation enables selective encapsulation of 3,3’- bipyridine (bipy), which bridges the ZnII ions of the parallel porphyrins, whereas 4,4’-bipy exhibits weaker external coordi- nation to the porphyrin faces. Reaction with 2,2’-bipy, by contrast, results in the displacement of the tetratopic porphyrin ligand and formation of [{(2,2’-bipy)CuI}2(diphosphine)2] . The differing strengths of interactions of bipyridine isomers with the system allows for a hierarchy to be deciphered, whereby 4,4’-bipy may be displaced by 3,3’-bipy, which in turn is displaced by 2,2’-bipy.
2015Source title
Angewandte Chemie International EditionVolume
54Issue
26Publisher
Wiley VCHFunding information
European Research Council
Gates Cambridge Scholarship
Licence
This is the peer reviewed version of the following article: Angew. Chem. Int. Ed., 2015, 54, 7539-7543, which has been published in final form at https://onlinelibrary.wiley.com/doi/10.1002/anie.201501359. This article may be used for non-commercial purposes in accordance with Wiley Terms and Conditions for Use of Self- Archived Versions. This article may not be enhanced, enriched or otherwise transformed into a derivative work, without express permission from Wiley or by statutory rights under applicable legislation. Copyright notices must not be removed, obscured or modified. The article must be linked to Wiley’s version of record on Wiley Online Library and any embedding, framing or otherwise making available the article or pages thereof by third parties from platforms, services and websites other than Wiley Online Library must be prohibited.Faculty/School
