Stability and range of the type II Bi1-xWxO1.5+1.5x solid solution
We have established the stability and range of the cubic type II phase of Bi1-xWxO1.5+1.5x using a combination of X-ray diffraction, neutron diffraction and X-ray absorption spectroscopy. Type II is a high temperature modification that can be obtained by quenching/rapid cooling of ...
See moreWe have established the stability and range of the cubic type II phase of Bi1-xWxO1.5+1.5x using a combination of X-ray diffraction, neutron diffraction and X-ray absorption spectroscopy. Type II is a high temperature modification that can be obtained by quenching/rapid cooling of samples with compositions between x = 0.148 to x = 0.185. Slower cooling rates yield the stable low temperature polymorph, the tetragonal type Ib phase (Bi rich samples), and mixtures of type Ib and Aurivillius phase (W-rich samples). Throughout the entire solid solution range, type II exhibits a (3+3) dimensional incommensurate modulation with modulation vectors slightly smaller than 1/3 based on a cubic fluorite type subcell (δ-Bi2O3). The main structural motifs are well-defined tetrahedra of WO6 octahedra in a δ-Bi2O3-matrix, with additional W being incorporated on corners and face centers of the approximate commensurate 3×3×3 supercell in octahedral coordination, confirmed by XANES analysis of the W L3-edge. Impedance measurements reveal oxide ionic conductivities comparable to those of yttria-stabilised zirconia even after a decrease in ionic conductivity of about half an order of magnitude on thermal cycling due to transition to the tetragonal type Ib phase.
2017-01-01Publisher
ElsevierLicence
J Wind, P Kayser, Z Zhang, IR Evans and CD Ling, Solid State Ionics 308, 173–180 (2017)Share
