Presence and Extent of Severe Facet Joint Osteoarthritis Are Associated with Back Pain in Older Adults
Objective To determine whether the presence and extent of severe lumbar facet joint osteoarthritis (OA) are associated with back pain in older adults, accounting for disc height narrowing and other covariates. Design Two hundred and fifty-two older adults from the Framingham ...
See moreObjective To determine whether the presence and extent of severe lumbar facet joint osteoarthritis (OA) are associated with back pain in older adults, accounting for disc height narrowing and other covariates. Design Two hundred and fifty-two older adults from the Framingham Offspring Cohort (mean age 67 years) were studied. Participants received standardized computed tomography (CT) assessments of lumbar facet joint OA and disc height narrowing at the L2–S1 interspaces using four-grade semi-quantitative scales. Severe facet joint OA was defined according to the presence and/or degree of joint space narrowing, osteophytosis, articular process hypertrophy, articular erosions, subchondral cysts, and intraarticular vacuum phenomenon. Severe disc height narrowing was defined as marked narrowing with endplates almost in contact. Back pain was defined as participant report of pain on most days or all days in the past 12 months. We used multivariable logistic regression to examine associations between severe facet joint OA and back pain, adjusting for key covariates including disc height narrowing, sociodemographics, anthropometrics, and health factors. Results Severe facet joint OA was more common in participants with back pain than those without (63.2% vs 46.7%; P = 0.03). In multivariable analyses, presence of any severe facet joint OA remained significantly associated with back pain (odds ratio (OR) 2.15 [95% confidence interval (CI) 1.13–4.08]). Each additional joint with severe OA conferred greater odds of back pain [OR per joint 1.20 (95% CI 1.02–1.41)]. Conclusions The presence and extent of severe facet joint OA on CT imaging are associated with back pain in community-based older adults, independent of sociodemographics, health factors, and disc height narrowing.
2013-09-01Publisher
ElsevierLicence
Faculty of Medicine and Health, Northern Clinical SchoolCitation
P. Suri, D.J. Hunter, J. Rainville, A. Guermazi, J.N. Katz, Presence and extent of severe facet joint osteoarthritis are associated with back pain in older adults, Osteoarthritis and Cartilage, Volume 21, Issue 9, September 2013, Pages 1199-1206,Subjects
OsteoarthritisShare
