Second Order Moments in Torsion Members (No. R800)
This paper is concerned with the elastic flexural buckling of structural members under torsion, and with second-order moments in torsion members. Previous research is reviewed, and the energy method of predicting elastic buckling is presented. This is used to develop the differential ...
See moreThis paper is concerned with the elastic flexural buckling of structural members under torsion, and with second-order moments in torsion members. Previous research is reviewed, and the energy method of predicting elastic buckling is presented. This is used to develop the differential equilibrium equations for a buckled member. Approximate solutions based on the energy method are obtained for a range of conservative applied torque distributions and flexural boundary conditions. A comparison with the limited range of independent solutions available and with independent finite element solutions suggests that the errors in the approximate solutions may be as small as 1%. The predicted linear elastic buckling torques may be used to approximate the second-order bending moments caused by torsion in members under more general loading. A method is developed for approximating these second-order moments. This is used as the basis of a method of estimating when these second-order moments may be significant by comparing the actual member slenderness with a reference value. Reference values of slenderness are calculated for two examples involving an equal angle member and a circular hollow section member (both simply supported), and the importance of second-order torsion effects in an I-section member is estimated. The reference values of slenderness are found to be very high, and it is concluded that second-order moments caused by torsion in typical structural steel members with slenderness ratios L/ry less than 300 are very small and may be neglected.
2000-01-01Publisher
