One-Pot Peptide Ligation–Desulfurization at Glutamate
An efficient methodology for ligation at glutamate (Glu) is described. A γ-thiol-Glu building block was accessed in only three steps from protected glutamic acid and could be incorporated at the N-terminus of peptides. The application of these peptides in one-pot ligation–desulfurization chemistry is demonstrated with a range of peptide thioesters, and the utility of this methodology is highlighted through the synthesis of the osteoporosis peptide drug teriparatide (Forteo).An efficient methodology for ligation at glutamate (Glu) is described. A γ-thiol-Glu building block was accessed in only three steps from protected glutamic acid and could be incorporated at the N-terminus of peptides. The application of these peptides in one-pot ligation–desulfurization chemistry is demonstrated with a range of peptide thioesters, and the utility of this methodology is highlighted through the synthesis of the osteoporosis peptide drug teriparatide (Forteo).
2013-12-02Publisher
ARC FT130100150Licence
Faculty of ScienceShare
