Cold Physiology At The Plant Level
Low night temperatures during late January and early February coinciding with early pollen microspore (EPM) development of rice (Oryza sativa) is a major factor limiting productivity in the Riverina region of New South Wales (NSW). This project primarily examined genotypic differences ...
See moreLow night temperatures during late January and early February coinciding with early pollen microspore (EPM) development of rice (Oryza sativa) is a major factor limiting productivity in the Riverina region of New South Wales (NSW). This project primarily examined genotypic differences in cold damage that are associated with low temperature during reproductive development. The objectives were to: (1) investigate the effects of low temperature on physio-morphological traits of rice plants, with particular emphasis on reproductive traits; (2) examine the consistency of expression of cold tolerance in different screening environments; and (3) quantify the effects of temperature and daylength on the phonological development among cultivars. Results from three screening environments including temperature-controlled rooms, a cold water facility and field experiments are reported. Over 50 cultivars from diverse origins, including cold tolerant cultivars from Eastern Europe, Japan and California were screened. Cultivars were exposed to day/night air temperatures of 27°/13°C in temperature-controlled rooms and a constant temperature of 19°C in the cold water facility. Exposure time for plants was from panicle initiation (PI) to 50% heading. To increase the likelihood of inducing cold damage in field experiments, several techniques such as multiple sowing dates, shallow water depths (5cm) and high nitrogen rates (300kgN ha-1) were used. The three screening methods induced sufficient levels of spikelet sterility to identify genotypic differences and consistently categorise cold tolerant cultivars. Among the common cultivars there was a highly significant relationship for spikelet sterility between temperature-controlled rooms and field experiments (r2=0.52, p<0.01, n=31), temperature-controlled rooms and the cold water facility (r2=0.63, p<0.01, n=21) and the cold water facility and field experiments (r2=0.53, p<0.01, n=21). Screening for cold tolerance in temperature-controlled rooms or the cold water facility was preferred to field screening because of the reliability of exposure to low temperature in both environments. However, it is still important to combine a controlled environment screen with field observations since some cultivars varied in their response under different screening methods. Several flowering traits such as the number of engorged pollen grains per anther, anther length and anther area produced significant genotypic variation and were negatively related to spikelet sterility at maturity. When low temperature coincided with reproductive development Australian and Californian cultivars were inefficient at producing filled grains, despite them having a similar number of engorged pollen grains and similar sized anthers to cultivars from other origins. This inefficiency may be partly related to a small stigma area. Several cold tolerant cultivars (M103, HSC55, Plovdiv 22, M104 and Jyoudeki) and cold susceptible cultivars (Sasanishiki, Doongara, Nippon Bare, Sprint and Reiziq) were identified. However, many of the cold tolerant cultivars had a shorter growth duration leading to lower yield potential compared to commercial cultivars. Therefore, two shorter duration cold tolerant cultivars, HSC55 and Plovdiv 22, were hybridised with two NSW commercial cultivars, Illabong and Millin, to determine if cold tolerance could be improved. The progeny were evaluated for cold tolerance in temperature-controlled rooms and there was found to be no relationship between 2 growth duration and spikelet sterility. Although, it should still be possible to produce cold tolerant cultivars with appropriate growth duration for Australian conditions. Phenological development was examined in sequentially sown field experiments by exposing plants to low temperatures and providing several different temperature and daylength conditions. Amaroo and Millin were identified as mildly photoperiod sensitive, whilst M103 and HSC55 were found to be photoperiod insensitive. A crop phenology model was developed for Amaroo and used to predict an optimum sowing date based on historical weather data from 1955 to 2002. The model minimizes the possibility of exposure to low temperatures during the young microspore and flowering stages. The analysis indicated that the 15th October was the optimal sowing date for Amaroo. Nevertheless, sowing up to November 1st when seasonal temperatures are average also minimizes the risk of encountering low temperatures. Increasing the photoperiod sensitivity of cultivars above that of Amaroo may further reduce the risk of encountering low temperatures and at the same time increase sowing flexibility. Results from this project have improved our understanding of the mechanisms of genotypic response to low temperature during reproductive development and provided methods to develop cold tolerant cultivars.
2005-01-01Licence
