A dissipative particle dynamics model for studying dynamic phenomena in colloidal rod suspensions
A dissipative particle dynamics (DPD) model is developed and demonstrated for studying dynamics in colloidal rod
suspensions. The solvent is modeled as conventional DPD particles, while individual rods are represented by a rigid
linear chain consisting of overlapping solid spheres ...
See moreA dissipative particle dynamics (DPD) model is developed and demonstrated for studying dynamics in colloidal rod suspensions. The solvent is modeled as conventional DPD particles, while individual rods are represented by a rigid linear chain consisting of overlapping solid spheres which interact with solvent particles through a hard repulsive potential. The boundary condition on the rod surface is controlled using a surface friction between the solid spheres and the solvent particles. In this work, this model is employed to study the diffusion of a single colloid in the DPD solvent, and compared with theoretical predictions. Both the translational and rotational diffusion coefficients obtained at a proper surface friction show good agreement with calculations based on the rod size defined by the hard repulsive potential. In addition, the system-size dependence of the diffusion coefficients showthat theNavier-Stokes hydrodynamic interactions are correctly included in this DPD model. Comparing our results with experimental measurements of the diffusion coefficients of gold nanorods, we discuss the ability of the model to correctly describe dynamics in real nanorod suspensions. Our results provide a clear reference point from which the model could be extended to enable the study of colloid dynamics in more complex situations or for other types of particles.
2021Source title
The Journal of Chemical PhysicsVolume
154Issue
10Publisher
AIP PublishingFunding information
ARC CE170100026Licence
Faculty of ScienceDepartment, Discipline or Centre
ARC Centre of Excellence in Exciton ScienceShare
