Multi-task Learning for Blind Source Separation
Blind source separation (BSS) aims to discover the underlying source signals from a set of linear mixture signals without any prior information of the mixing system, which is a fundamental problem in signal and image processing field. Most of the state-of-the-art algorithms have ...
See moreBlind source separation (BSS) aims to discover the underlying source signals from a set of linear mixture signals without any prior information of the mixing system, which is a fundamental problem in signal and image processing field. Most of the state-of-the-art algorithms have independently handled the decompositions of mixture signals. In this paper, we propose a new algorithm named multi-task sparse model to solve the BSS problem. Source signals are characterized via sparse techniques. Meanwhile, we regard the decomposition of each mixture signal as a task and employ the idea of multi-task learning to discover connections between tasks for the accuracy improvement of the source signal separation. Theoretical analyses on the optimization convergence and sample complexity of the proposed algorithm are provided. Experimental results based on extensive synthetic and real-world data demonstrate the necessity of exploiting connections between mixture signals and the effectiveness of the proposed algorithm.
2018Source title
IEEE Transactions on Image ProcessingPublisher
IEEEFunding information
ARC FL-170100117ARC DE-180101438
ARC DP-180103424
ARC DP-140102164
ARC LP-150100671
Licence
© 20XX IEEE. Personal use of this material is permitted. Permission from IEEE must be obtained for all other uses, in any current or future media, including reprinting/republishing this material for advertising or promotional purposes, creating new collective works, for resale or redistribution to servers or lists, or reuse of any copyrighted component of this work in other works.Faculty/School
