Self-supervised Pose Adaptation for Cross-Domain Image Animation
Image animation is to animate a still image of the object of interest using poses extracted from another video sequence. Through training on a large-scale video dataset, most existing approaches aim to explore disentangled appearance and pose representations of training frames. ...
See moreImage animation is to animate a still image of the object of interest using poses extracted from another video sequence. Through training on a large-scale video dataset, most existing approaches aim to explore disentangled appearance and pose representations of training frames. Then, the desired output with a specific appearance and pose can be synthesized via recombining learned representations. However, in some real applications, test images may lack corresponding video ground- truth or follow a different distribution than training video frames (i.e., different domains), which largely limit the performance of existing works. In this work, we propose domain-independent pose representations that are compatible with and accessible by still images from a different domain. Specifically, we devise a two-stage self-supervised pose adaptation framework for general image animation tasks. A domain-independent pose adaptation generative adversarial network (DIPA-GAN) and a shuffle-patch generative adversarial network (Shuffle-patch GAN) are pro- posed to penalize the rationality of the synthesized frame’s pose and appearance, respectively. Finally, experiments evaluated on various image animation tasks, which include same/cross- domain moving objects, facial expression transfer and human pose retargeting, demonstrate the superiority of the proposed framework over prior works.
2020Publisher
IEEE Transactions on Artificial IntelligenceLicence
© 20XX IEEE. Personal use of this material is permitted. Permission from IEEE must be obtained for all other uses, in any current or future media, including reprinting/republishing this material for advertising or promotional purposes, creating new collective works, for resale or redistribution to servers or lists, or reuse of any copyrighted component of this work in other works.Faculty/School
