Tailoring multiple porosities of hierarchical ZSM-5 zeolites by carbon dots for high-performance catalytic transf
A simple and high‐efficiency method is proposed to synthesize hierarchical ZSM‐5 zeolites with micropore and multistage mesopores by adopting water‐soluble carbon dots (CDots) with various size distributions, such as 1‐stage size distribution of CDots‐1 of around 23 nm, 2‐stage ...
See moreA simple and high‐efficiency method is proposed to synthesize hierarchical ZSM‐5 zeolites with micropore and multistage mesopores by adopting water‐soluble carbon dots (CDots) with various size distributions, such as 1‐stage size distribution of CDots‐1 of around 23 nm, 2‐stage size distribution of CDots‐2 of 6 and 9 nm, 3‐stage size distribution of CDots‐3 of 5, 8, and 18 nm. The abundant OH and COOH groups on the surface of CDots provide high solubility in water. The characterization techniques confirmed that the dual‐porous h‐ZSM‐5 (MIcro–mEsopores) and multi‐porous h‐ZSM‐5 (MIcro–mEso–mEsopores), h‐ZSM‐5 (MIcro–mEso–mEso–mEsopores, M‐IEEE) catalysts are obtained. Notably, the hierarchical ZSM‐5(M‐IEEE) catalyst with micropore of 0.55 nm, two small mesopores of 4.8 and 7.4 nm, and one large mesopore of 17.5 nm show excellent catalytic performance with the highest 1,3,5‐triisopropylbenzene (TIPB) cracking conversion (97.3%) and high stability. Similarly, the h‐ZSM‐5(M‐IEEE) shows the high ethanol to olefins conversion (100%). The improved catalytic activity can be attributed to the more efficient diffusion of reactants and products in the crystals with the help of multistage mesopores, improved anti‐coking stability, combined with the effect of suitable acidity, and the increased accessibility of the acid sites.
2020Source title
Advanced Materials InterfacesPublisher
WileyLicence
"This is the peer reviewed version of the following article: Zhao, S., Kim, K. D., Wang, L., Ryoo, R., Huang, J., Tailoring Multiple Porosities of Hierarchical ZSM‐5 Zeolites by Carbon Dots for High‐Performance Catalytic Transformation. Adv. Mater. Interfaces 2020, 2001846., which has been published in final form at https://doi.org/10.1002/admi.202001846. This article may be used for non-commercial purposes in accordance with Wiley Terms and Conditions for Use of Self-Archived Versions."Faculty/School
Faculty of EngineeringShare
