Using Click Chemistry to Tune the Properties and the Fluorescence Response Mechanism of Structurally Similar Probes for Metal Ions
Four cyclam-based fluorescent molecular probes were prepared using ‘click’ chemistry and investigated to determine the effect of the triazole connectivity and fluorophore substitution on photophysical properties and metal ion response mechanism. The ligands’ fluorescence is turned ...
See moreFour cyclam-based fluorescent molecular probes were prepared using ‘click’ chemistry and investigated to determine the effect of the triazole connectivity and fluorophore substitution on photophysical properties and metal ion response mechanism. The ligands’ fluorescence is turned on in the presence of Zn(II) but varies in intensity depending on the solvent; the highest signal changes are found in MeCN. Complexation with Cu(II) leads to fluorescence quenching, but only in the aqueous solvent, where the triazole is involved in coordination of the metal. The length of the pendant triazole arm influences the ligand field around pentacoordinated Cu(II) yielding a distorted square planar coordination geometry in the ligands with an ethylene linker. The quantum yield (QY) of the emission intensity can be tuned by the triazole substitution, resulting in increases in QY of more than one order of magnitude (ligand 1 vs. 3). Changing the fluorophore opens up alternative radiative processes, leading to phosphorescence-like behaviour in coumarin probe 2. Steady state fluorescence emission spectra of the free ligands and their respective Cu(II) complexes in a ‘glass environment’ reveal two different inherent fluorescent quenching mechanisms. In the free ligands an electron transfer deactivates the excited chromophore, while in the Cu(II)-complexes it is energy transfer that results in complete quenching of the ligands’ emission.
2014-12-05Publisher
Wiley - V C H Verlag GmbH & Co. KGaAFunding information
ARC DP120104035Licence
Faculty of ScienceCitation
Ast, S., Kuke, S., Rutledge, P., Todd, M. (2015). Using click chemistry to tune the properties and the fluorescence response mechanism of structurally similar probes for metal ions. European Journal of Inorganic Chemistry, 2015 (1), 58-66.Share
