Is home warfarin self-management effective? Results of the Randomised Self-Management of Anticoagulation Research Trial
Warfarin SMART investigatorsDignan, Rebecca
Keech, Anthony
Gebski, Val
Mann, Kristy
Hughes, Clifford
Aims The Warfarin Self-Management Anticoagulation Research Trial (Warfarin SMART) was designed to determine whether patients self-managing warfarin (PSM) using the CoaguChek device and a dosing algorithm developed for the trial could keep the INR (International Normalised Ratio) ...
See moreAims The Warfarin Self-Management Anticoagulation Research Trial (Warfarin SMART) was designed to determine whether patients self-managing warfarin (PSM) using the CoaguChek device and a dosing algorithm developed for the trial could keep the INR (International Normalised Ratio) test in target range at least as often as patients managed by usual care by the family doctor or hospital clinic. Methods and Results 310 patients were randomly assigned to PSM or usual care. The PSM group was trained to perform home INR testing and warfarin dosing using a validated ColourChart algorithm. The primary endpoint was the proportion of times over 12 months that a monthly, blinded “outcome INR test”, measured in a central laboratory, was outside the patients’ target therapeutic range. The rate of out-of-range outcome INRs was lower in PSM, and non-inferior to the usual care group (PSM: 36% vs. usual care: 41%, P<0.0001 for non-inferiority; P=0.08 for superiority in closed-loop testing). The deviations from the patients’ midpoint of target INR range (P=0.02) and number of extreme INRs (P=0.03) were significantly less in the PSM group than the usual-care group. There was no significant difference between groups in rates of bleeding or thrombotic adverse events. Conclusion Patient self-management performed at least as well as usual care in maintaining the INR within the target range, without any safety concerns. This treatment modality for the long-term use of warfarin has the potential to change current local and international practice.
2013-08-27Publisher
ElsevierLicence
Faculty of Medicine and Health, NHMRC Clinical Trials CentreCitation
Dignan R, Keech AC, Gebski VJ, Mann KP, Hughes CF, Warfarin SMART Investigators. Is home warfarin self-management effective? Results of the randomised Self-Management of Anticoagulation Research Trial. International Journal of Cardiology 2013; 168(6): 5378-5384.Share
