Effects of heat treatment and strain rate on the microstructure and mechanical properties of 6061 Al alloy
In the present work, the effects of heat treatment and strain rate on mechanical behaviour and microstructure evolution of aluminium alloy (AA) 6061 have been investigated. The micro-crack initiation and crystallographic texture evolution are obtained from scanning electron microscope ...
See moreIn the present work, the effects of heat treatment and strain rate on mechanical behaviour and microstructure evolution of aluminium alloy (AA) 6061 have been investigated. The micro-crack initiation and crystallographic texture evolution are obtained from scanning electron microscope (SEM) and electron back-scatter diffraction (EBSD) experiments. Quasi-static and high strain rate compression tests are conducted on AA6061 specimens that underwent two different heat treatments: the as-received material with the original T6 heat treatment and the heat treated and artificially aged (HT) specimens. For the high strain rate compression (~2000 s-1 and ~4000 s-1) tests, the split Hopkinson pressure bar apparatus is used. It is observed that the additional heat treatment has significantly reduced the yield strength of the material. Furthermore, EBSD results show that the higher the applied strain rate is, the less significant change will happen to the texture. SEM images show that, for both T6 and HT specimens, the number and size of micro-cracks in the dynamic compressed specimens are smaller than in the quasi-static deformed specimen. Therefore, the strain rate is considered to be the dominant factor in forming micro-cracks.
2015-01-23Publisher
SAGE PublicationsLicence
Li, L, Flores-Johnson, EA, Shen, L, Proust, G (2015) Effects of heat treatment and strain rate on the microstructure and mechanical properties of 6061 Al alloy, International Journal of Damage Mechanics, DOI: http://dx.doi.org/10.1177/1056789515569088Share
