The effect of interface adhesion on buckling and cracking of hard thin films
Article, LetterAbstract
The physics behind the strain-released buckling patterns including telephone cords and straight-sided wrinkles with and without cracks, as experimentally observed in sputter-deposited Ti-Si-N thin films on Si substrates, are investigated with model-based simulations by varying the ...
See moreThe physics behind the strain-released buckling patterns including telephone cords and straight-sided wrinkles with and without cracks, as experimentally observed in sputter-deposited Ti-Si-N thin films on Si substrates, are investigated with model-based simulations by varying the mechanical properties of the interface. Our calculations reveal that the location of the cracks depends on the normal stiffness, the interfacial toughness and the normal strength of the cohesive interface. These properties determine the geometrical shape of the buckles such as width, wavelength and deflection, and hence the local bending-induced tensile stresses. Buckling patterns with cracks at the apexes occur for low-stiffness interfaces as well as for high-stiffness interfaces with high toughness. On the other hand, cracks at the bottom of the buckles are more likely to occur for interfaces with high stiffness and low toughness. By using an elastic material model with a fracture criterion for brittle behavior, we demonstrate that the crack will follow the path where the bending-induced principal stress exceeds the flexural strength of the film.
2014-10-20Publisher
AIP PublishingFunding information
ARC CE0561574Licence
Copyright (2014) American Institute of Physics. This article may be downloaded for personal use only. Any other use requires prior permission of the author and the American Institute of Physics. The following article appeared in E. A. Flores-Johnson et al., Applied Physics Letters 105, 161912 (2014) and may be found at http://dx.doi.org/10.1063/1.4900443 .Faculty/School
Appl. Phys. Lett. 105, 161912 (2014)Share
