Conditioned inhibition and reinforcement rate
We investigated conditioned inhibition in a magazine approach paradigm. Rats were trained on a feature negative discrimination between an auditory conditioned stimulus (CS) reinforced at one rate versus a compound of that CS and a visual stimulus (L) reinforced at a lower rate. ...
See moreWe investigated conditioned inhibition in a magazine approach paradigm. Rats were trained on a feature negative discrimination between an auditory conditioned stimulus (CS) reinforced at one rate versus a compound of that CS and a visual stimulus (L) reinforced at a lower rate. This training established L as a conditioned inhibitor. We then tested the inhibitory strength of L by presenting it in compound with other auditory CSs. L reduced responding when tested with a CS that had been reinforced at a high rate, but had less or even no inhibitory effect when tested with a CS that had been reinforced at a low rate. The inhibitory strength of L was greater if it signaled a decrease in reinforcement from an already low rate than if it signaled an equivalent decrease in reinforcement from a high rate. We conclude that the strength of inhibition is not a linear function of the change in reinforcement that it signals. We discuss the implications of this finding for models of learning (e.g. Rescorla & Wagner, 1972) that identify inhibition with a difference (subtraction) rule.
2014-01-01Publisher
American Psychological AssociationLicence
Faculty of Science, School of PsychologyCitation
Harris, J. A., Kwok, D. W. S., & Andrew, B. J. (2014). Conditioned inhibition and reinforcement rate. Journal of Experimental Psychology: Animal Learning and Cognition, 40, 335-354.Share
