Sub-collections in this collection
Recent Submissions
  • Demonstration of a photonic-lantern focal-plane wavefront sensor using fiber mode conversion and deep learning
    Norris, Barnaby; Wei, Jin; Betters, Christopher H.; Leon-Saval, Sergio G.; Xin, Yinzi; Lin, Jonathan; Kim, Yoo Jung; Sallum, Steph; Lozi, Julien; Vievard, Sebastian; Guyon, Olivier; Gatkine, Pradip; Jovanovic, Nemanja; Mawet, Dimitri; Fitzgerald, Michael P.
    Published 2022
    A focal plane wavefront sensor offers major advantages to adaptive optics, including removal of non-commonpath error and providing sensitivity to blind modes (such as petalling). But simply using the observed point spread ...
    Conference paper
  • The photonic lantern wavefront sensor and imager: focal plane wavefront sensing and optimal imaging at the diffraction limit and beyond
    Norris, Barnaby; Leon-Saval, Sergio G.; Wei, Jin; Betters, Christopher H.; Taras, Adam; Lin, Jonathan; Xin, Yinzi; Kim, Yoo Jung; Fitzgerald, Michael; Sallum, Steph; Sengupta, Aditya; Gatkine, Pradip; Jovanovic, Nemanja; Mawet, Dimitri; Lozi, Julien; Vievard, Sebastian; Deo, Vincent; Lallement, Manon; Levinstein, Daniel; Guyon, Olivier
    Published 2024
    The use of a photonic lantern as focal plane wavefront sensor has seen recent widespread interest - it can remove non-common-path aberrations, accurately sense low-wind-effect and petal modes, and provide wavelength ...
    Conference paper
  • Optimization of nonlinear enhancement through linear dispersion engineering
    Lourdesamy, Joshua P.; Widjaja, Justin; Hawi, Georgio; Kesarwani, Sharvil; Runge, Antoine F. J.; de Sterke, C. Martijn
    Published 2023
    We consider nonlinear pulse propagation in media with a dispersion relation exhibiting $J$ periodically spaced identical maxima in a co-moving frame. The nonlinear interactions lead to $J$ pulses centered at each of these ...
    Article
  • Absence of Galilean invariance for pure-quartic solitons
    Widjaja, Justin; Kobakhidze, Erekle; Cartwright, Tiernan R; Lourdesamy, Joshua P.; Runge, Antoine F. J.; Alexander, Tristram J.; de Sterke, C. Martijn
    Published 2021
    Optical temporal solitons, arising from self-phase modulation and negative quadratic ($\beta_2$) dispersion, are Galilean invariant, and therefore their properties do not depend on their group velocity. This is no longer ...
    Article
  • Theory of multicolor soliton microcombs
    Silvestri, Carlo; Widjaja, Justin; Lin, Austin; de Sterke, C. Martijn; Runge, Antoine F. J.
    Published 2025
    We present a general theory of multicolor soliton microcombs. These frequency combs require engineered dispersion and have an optical spectrum consisting of multiple spectral windows, centered at distinct frequencies. Our ...
    Article
See more
