FB*-Index: A Compact Index for Efficient and Exact Density-based Clustering
Zhao, BideAbstract
Density-based clustering is a fundamental technique for discovering arbitrarily shaped clusters and handling noise, without requiring the number of clusters to be specified in advance. However, existing methods often struggle with efficiency and accuracy across varying query ...
See moreDensity-based clustering is a fundamental technique for discovering arbitrarily shaped clusters and handling noise, without requiring the number of clusters to be specified in advance. However, existing methods often struggle with efficiency and accuracy across varying query parameters $\varepsilon$ and $\mu$. In this thesis, we propose a novel index-based algorithm for efficient and exact cluster extraction. We introduce FB, the first linear-size index that supports exact clustering with running time linear in the output size for any query $\varepsilon$, along with a compact variant, FB$^*$, for efficiently extracting density-based clusters. Due to the compactness of the index and the efficiency of the query algorithm, our method is well-suited for disk-based storage, enabling multiple versions of the index to support arbitrary $(\varepsilon,\mu)$ queries. We provide formal analyses of time and space complexity. Extensive experiments on 19 real-world datasets demonstrate that our method significantly outperforms existing approaches while guaranteeing exact clustering results.
2025Rights statement
