Cr-Mo-V-W: A new refractory and transition metal high-entropy alloy system
PreprintAuthor/s
Ikeuchi, DaikiD.J.M., King
K.J., Laws
A.J., Knowles
R.D., Aughterson
G.R., Lumpkin
E.G., Obbard
Cr-Mo-V-W high-entropy alloy (HEA) is studied, with 2553 K equilibrium solidus and high Cr content to promote protective oxide scale formation, suggesting potential applications in hot, oxidising environments. Alloy Search and Predict (ASAP) and phase diagram calculations found a ...
See moreCr-Mo-V-W high-entropy alloy (HEA) is studied, with 2553 K equilibrium solidus and high Cr content to promote protective oxide scale formation, suggesting potential applications in hot, oxidising environments. Alloy Search and Predict (ASAP) and phase diagram calculations found a single phase, body-centred cubic (BCC) solid solution at elevated temperatures, across the range of compositions present within the system - uncommon for a HEA of refractory and transition metals. Density functional theory identified solubility of 22 at.% Cr at solidus temperature, with composition-dependent drive for segregation during cooling. An as-cast, BCC single-phase with the composition 31.3Cr-23.6Mo-26.4 V-18.7 W exhibiting dendritic microsegregation was verified.
2019Publisher
ElsevierLicence
