Sub-collections in this collection
Recent Submissions
  • Light Field Based 6DoF Tracking of Previously Unobserved Objects
    Goncharov, Nikolai; Gray, James Lyndon; Dansereau, Donald Gilbert
    Published 2025-12-16
    Object tracking is an important step in robotics and autonomous driving pipelines, which has to generalize to previously unseen and complex objects. Existing high-performing methods often rely on pre-captured object views ...
    Dataset
  • Understandings of empathy held by Australian engineering leadership
    Scott-Curwood, Cole
    Published 2025-11-26
    Empathy is emerging as a vital engineering skill in light of the growing complexity of engineering work and necessity of human-centred solutions. While there is emerging research on empathy in engineering, there is a lack ...
    Thesis
  • Event-based Satellite Docking
    Le Gentil, Cedric; Naylor, Jack; Munasinghe, Nuwan; Mehami, Jasprabhijit; Dai, Benny; Asavkin, Mikhail; Dansereau, Donald G.; Vidal-Calleja, Teresa
    Published 2025-05-27
    Dataset to accompany Le Gentil et al. "Mixing Data-driven and Geometric Models for Satellite Docking Port State Estimation using an RGB or Event Camera", IEEE International Conference on Robotics and Automation (ICRA) ...
    Dataset
  • The effect of rotation speed and flow rate on evacuation of particles from a spinning dry powder inhaler capsule
    Azeem, A; Singh, G; Chan, H-K; Yang, R; Cheng, S; Kourmatzis, A
    Published 2025
    This study investigated a capsule’s powder evacuation behaviour when rotating about its minor axis in a cross flow and considering the effects of rotation speed and flow rate on powder emission. The experimental platform, ...
    Article
  • SydneyScapes: Image Segmentation for Australian Environments
    Berrio Perez, Julie Stephany; Shan, Mao; Worrall, Stewart; Lyu, Hongyu
    Published 2024-09-05
    Autonomous Vehicles (AVs) are being partially deployed and tested across various global locations, including China, the USA, Germany, France, Japan, Korea, and the UK, but with limited demonstrations in Australia. The ...
    Dataset
See more
