Three-Dimensional Analysis of Anterior Open Bite Treatment Modalities in Growing Patients: a comparison of Clear Aligner Therapy and Temporary Anchorage Devices
Lo-Cao, DanielAbstract
Aim: The aim was to compare the skeletal and dentoalveolar effects of clear aligner therapy (CAT) with Invisalign® versus intrusion of maxillary posterior teeth with Temporary Anchorage Devices (TADs) in growing patients with anterior open bite (AOB) using three- dimensional (3D) ...
See moreAim: The aim was to compare the skeletal and dentoalveolar effects of clear aligner therapy (CAT) with Invisalign® versus intrusion of maxillary posterior teeth with Temporary Anchorage Devices (TADs) in growing patients with anterior open bite (AOB) using three- dimensional (3D) imaging. Methods: Fifteen adolescents treated exclusively with Invisalign® and fourteen with TADs were assessed retrospectively. Rigid-wise, voxel-based registration of pre- and post-treatment CBCTs were performed using the anterior cranial base, maxillary plane, and mandibular body as reference regions. Treatment outcomes were compared between both groups using median regression modelling. Results: Both treatment modalities resulted in similar correction of AOB. Compared with CAT, TADs demonstrated significantly greater intrusion of the maxillary first molars when measured from the mesio-buccal [Right: (2.09mm; 95% CI: 1.05-3.12), Left: (2.98mm; 95% CI:2.00-3.96)] and palatal cusps [Right: (2.08mm; 95% CI: 1.15-3.01), Left: (2.83mm; 95% CI:1.92- 3.74)] as well as less extrusion of the upper incisors [12: (-1.30mm; 95% CI, -2.13 to -0.47), 11: (-1.30mm; 95% CI, -2.40 to –0.20), 21: (-0.92mm; 95% CI, -1.73 to –0.12), 22: (- 0.85mm; 95% CI, -1.71 to –0.00)]. Upper and lower incisors tipped lingually while lower incisors extruded with no statistical difference between the two groups. Conclusion: TADs demonstrated greater maxillary molar intrusion whilst CAT induced greater maxillary incisor extrusion in growing patients with AOB.
2023Rights statement
Faculty of Medicine and Health, The University of Sydney School of DentistryAwarding institution
