Formation of ciprofloxacin nanocrystals within liposomes by spray drying for controlled release via inhalation
Khatib, IsraTang, Patricia
Ruan, Juanfang
Cipolla, David
Dayton, Francis
Blanchard, James
Chan, Hak-Kim
The present study was conducted to harness spray drying
technology as a novel method of producing Ciprofloxacin nanocrystals
inside liposomes (CNL) for inhalation delivery. Liposomal ciprofloxacin
dispersions were spray dried with sucrose as a lyoprotectant in different
mass ...
See moreThe present study was conducted to harness spray drying technology as a novel method of producing Ciprofloxacin nanocrystals inside liposomes (CNL) for inhalation delivery. Liposomal ciprofloxacin dispersions were spray dried with sucrose as a lyoprotectant in different mass ratios (0.5:1, 1:1 and 2:1 sucrose to lipids), along with 2% w/w magnesium stearate and 5% w/w isoleucine as aerosolization enhancers. Spray drying conditions were: inlet air temperature 50 °C, outlet air temperature 33-35 °C, atomizer rate 742 L/h and aspirator 35 m3/h. After spray drying, the formation of ciprofloxacin nanocrystals inside the liposomes was confirmed by cryo- transmission electron microscopy. The physiochemical characteristics of the spray dried powder (particle size, morphology, crystallinity, moisture content, drug encapsulation efficiency (EE), in vitro aerosolization performance and drug release) were determined. The EE of the liposomes was found to vary between 44 and 87% w/w as the sucrose content was increased from 25 to 57% w/w. The powders contained partially crystalline particles with a volume median diameter of ~ 1 μm. The powders had low water content (~2 % wt.) and were stable at high relative humidity. Aerosol delivery using the Osmohaler® inhaler at a flow rate of 100 L/min produced an aerosol fine particle fraction (% wt. < 5 μm) of 58 - 64%. The formulation with the highest sucrose content (2:1 w/w sucrose to lipid) demonstrated extended ciprofloxacin release from liposomes (80% released within 7 hours) in comparison to the original liquid formulation (80% released within 2 hours). In conclusion, a stable and inhalable CNL powder with controlled drug release was successfully prepared by spray drying.
2020Source title
International Journal of PharmaceuticsVolume
578Publisher
ElsevierFunding information
ARC LP160101498Licence
Faculty of Medicine and Health, The University of Sydney School of PharmacyDepartment, Discipline or Centre
Advanced Drug Delivery GroupShare
