Adaptive CaRdiac cOne BEAm computed Tomography (ACROBEAT): Developing the next generation of cardiac cone beam CT imaging.
Purpose: An important factor when considering the use of interventional cone beam computed tomography (CBCT) imaging during cardiac procedures is the trade-off between imaging dose and image quality. Accordingly, Adaptive CaRdiac cOne BEAm computed Tomography (ACROBEAT) presents ...
See morePurpose: An important factor when considering the use of interventional cone beam computed tomography (CBCT) imaging during cardiac procedures is the trade-off between imaging dose and image quality. Accordingly, Adaptive CaRdiac cOne BEAm computed Tomography (ACROBEAT) presents an alternative acquisition method, adapting the gantry velocity and projection rate of CBCT imaging systems in accordance with a patient's electrocardiogram (ECG) signal in real-time. The aim of this study was to experimentally investigate that ACROBEAT acquisitions deliver improved image quality compared to conventional cardiac CBCT imaging protocols with fewer projections acquired. Methods: The Siemens ARTIS pheno (Siemens Healthcare, GmbH, Germany), a robotic CBCT C-arm system, was used to compare ACROBEAT with a commercially available conventional cardiac imaging protocol that utilizes multisweep retrospective ECG-gated acquisition. For ACROBEAT, real-time control of the gantry position was enabled through the Siemens Test Automation Control system. ACROBEAT and conventional image acquisitions of the CIRS Dynamic Cardiac Phantom were performed, using five patient-measured ECG traces. The traces had average heart rates of 56, 64, 76, 86, and 100 bpm. The total number of acquired projections was compared between the ACROBEAT and conventional acquisition methods. The image quality was assessed via the contrast-to-noise ratio (CNR), structural similarity index (SSIM), and root-mean square error (RMSE). Results: Compared to the conventional protocol, ACROBEAT reduced the total number of projections acquired by 90%. The visual image quality provided by the ACROBEAT acquisitions, across all traces, matched or improved compared to conventional acquisition and was independent of the patient's heart rate. Across all traces, ACROBEAT averaged 1.4 times increase in the CNR, a 23% increase in the SSIM and a 29% decrease in the RMSE compared to conventional and was independent of the patient's heart rate. Conclusion: Adaptive patient imaging is feasible on a clinical robotic CBCT system, delivering higher quality images while reducing the number of projections acquired by 90% compared to conventional cardiac imaging protocols.
2021Source title
Medical PhysicsVolume
48Issue
5Publisher
WileyLicence
This is the peer reviewed version of the following article: Adaptive CaRdiac cOne BEAm computed Tomography (ACROBEAT): Developing the next generation of cardiac cone beam CT imaging, which has been published in final form at https://aapm.onlinelibrary.wiley.com/doi/10.1002/mp.14811]. This article may be used for non-commercial purposes in accordance with Wiley Terms and Conditions for Use of Self-Archived Versions. This article may not be enhanced, enriched or otherwise transformed into a derivative work, without express permission from Wiley or by statutory rights under applicable legislation. Copyright notices must not be removed, obscured or modified. The article must be linked to Wiley’s version of record on Wiley Online Library and any embedding, framing or otherwise making available the article or pages thereof by third parties from platforms, services and websites other than Wiley Online Library must be prohibitedFaculty/School
ACRF Image X InstituteShare
