Mixing postharvest fungicides and sanitizers results in unpredictable survival of microbes that affect cantaloupes
Rothwell, Joanna G.Safianowicza, Katarzyna
McConchie, Robyn
Bell, Tina L.
Carter, Dee A.
Bradbury, Mark I.
Postharvest treatments with sanitizers and fungicides are applied to increase the quality, safety and shelf life of fresh produce including cantaloupes (also known as rockmelons). The primary role of sanitizers during cantaloupe washing is to prevent cross contamination of potentially ...
See morePostharvest treatments with sanitizers and fungicides are applied to increase the quality, safety and shelf life of fresh produce including cantaloupes (also known as rockmelons). The primary role of sanitizers during cantaloupe washing is to prevent cross contamination of potentially pathogenic bacteria in washwater. Postharvest fungicide sprays or dips are employed to inhibit spoilage-causing fungi. While assessing the compatibility of these antimicrobials based on the measurement of active ingredients levels provides some indication of antimicrobial capacity, there is limited data on whether the interaction between these chemicals in wash water modifies their overall efficacy against relevant microorganisms. The aim of this research was to determine how chlorine- and peroxyacetic acid-based sanitizers interact with commercial guazatine- and imazalil-based fungicide formulations used on cantaloupes, and whether mixing these augments or suppresses anti-microbial activity against relevant human pathogens and spoilage fungi in wash water. The results were unpredictable: while most combinations were antimicrobial, the chlorine-based sanitizer when mixed with the guazatine-based fungicide had significantly reduced efficacy against pathogenic Salmonella spp. (~2.7 log) and the fungal spoilage organisms, Trichothecium roseum and Rhizopus stolonifera. Mixing the chlorine-based sanitizer with an imazalil-based fungicide produced a range of outcomes with antagonistic, indifferent and synergistic interactions observed for the fungal species tested. The peroxyacetic acid-based sanitizer led to indifferent interactions with the guazatine-based fungicide, while antagonism and synergy were observed when mixed with the imazalil-based fungicide. This study demonstrates that mixing postharvest agrichemicals used in the cantaloupe industry may increase the risk of microbial contamination and thereby potentially compromise food safety and quality.
2021Source title
Food MicrobiologyVolume
99Publisher
ElsevierFunding information
ARC IC160100025Licence
I may post the accepted manuscript in my institutional repository and make this public after an embargo period. To ensure the sustainability of peer-reviewed research in journal publications, I may not share the final article publicly, for example on ResearchGate or Academia.edu. Further details on Elsevier Sharing Policy here. Based on information provided the embargo period/end date is 12 months.Faculty/School
Faculty of Science, School of Life and Environmental SciencesDepartment, Discipline or Centre
MicrobiologyShare
