Bending and Buckling of Tapered Steel Beam Structures (No. R939)
Report, ResearchAuthor/s
Trahair, Nicholas S.Abstract
This paper describes an efficient finite element method of analysing the elastic in-plane bending and out-ofplane buckling of indeterminate beam structures whose members may be tapered and of mono-symmetric I cross-section. The structure’s loading includes concentrated moments and ...
See moreThis paper describes an efficient finite element method of analysing the elastic in-plane bending and out-ofplane buckling of indeterminate beam structures whose members may be tapered and of mono-symmetric I cross-section. The structure’s loading includes concentrated moments and concentrated or uniformly distributed off-axis transverse and longitudinal forces, and its deformations may be prevented or resisted by concentrated or continuous rigid or elastic off-axis restraints. Tapered finite element formulations are developed by numerical integration instead of the closed forms often used for uniform elements. Difficulties in specifying the load positions for tapered mono-symmetric members caused by the variations of the centroid and shear centre axes are avoided by using an arbitrary axis system based on the web mid-line. Account is taken of additional Wagner torque terms arising from the inclination of the shear centre axis. A computer program based on this method is used to analyse a number of examples of the elastic in-plane bending of tapered cantilevers and built-in beams, and very close agreement is found between its predictions and closed form solutions. The program’s predictions of the elastic out-of-plane flexural-torsional buckling of a large number of uniform and tapered doubly and mono-symmetric beams and cantilevers under various loading and restraint conditions are generally in close agreement with existing predictions and test results. The common approximation in which tapered elements are replaced by uniform elements is shown to converge slowly, and to lead to incorrect predictions for tapered mono-symmetric beams.
2013Publisher
