The effect of device resistance and inhalation flow rate on the lung deposition of orally inhaled mannitol dry powder
Yang, Michael YVerschuer, Jordan
Shi, Yuyu
Song, Yang
Katsifis, Andrew
Eberl, Stefan
Wong, Keith
Brannan, John D
Cai, Weidong
Finlay, Warren H
Chan, Hak-Kim
The present study investigates the effect of DPI resistance and inhalation flow rates on the lung deposition of orally inhaled mannitol dry powder. Mannitol powder radiolabeled with 99mTc-DTPA was inhaled from an Osmohaler™ by healthy human volunteers at 50-70L/min peak inhalation ...
See moreThe present study investigates the effect of DPI resistance and inhalation flow rates on the lung deposition of orally inhaled mannitol dry powder. Mannitol powder radiolabeled with 99mTc-DTPA was inhaled from an Osmohaler™ by healthy human volunteers at 50-70L/min peak inhalation flow rate (PIFR) using both a low and high resistance Osmohaler™, and 110-130L/min PIFR using the low resistance Osmohaler™ (n=9). At 50-70L/min PIFR, the resistance of the Osmohaler™ did not significantly affect the total and peripheral lung deposition of inhaled mannitol [for low resistance Osmohaler™, 20% total lung deposition (TLD), 0.3 penetration index (PI); for high resistance Osmohaler™, 17% TLD, 0.23 PI]. Increasing the PIFR 50-70L/min to 110-130L/min (low resistance Osmohaler™) significantly reduced the total lung deposition (10% TLD) and the peripheral lung deposition (PI 0.21). The total lung deposition showed dependency on the in vitro FPF (R2=1.0). On the other hand, the PI had a stronger association with the MMAD (R2=1.0) than the FPF (R2=0.7). In conclusion the resistance of Osmohaler™ did not significantly affect the total and regional lung deposition at 50-70L/min PIFR. Instead, the total and regional lung depositions are dependent on the particle size of the aerosol and inhalation flow rate, the latter itself affecting the particle size distribution.
2016-01-01Source title
International Journal of PharmaceuticsVolume
513Issue
1-2Publisher
ElsevierFunding information
ARC DP160102577Licence
© <2016>. This manuscript version is made available under the CC-BY-NC-ND 4.0Faculty/School
Faculty of Medicine and Health, The University of Sydney School of PharmacyShare
