Amino acid availability in poultry - in vitro and in vivo measurements
Methodology to evaluate the protein quality or amino acid availability in feed ingredients for poultry using in vitro (enzymic, chemical, or microbiological assays), indirect in vivo (plasma amino acid assays), or direct in vivo (growth or digestibility assays) measurements has ...
See moreMethodology to evaluate the protein quality or amino acid availability in feed ingredients for poultry using in vitro (enzymic, chemical, or microbiological assays), indirect in vivo (plasma amino acid assays), or direct in vivo (growth or digestibility assays) measurements has been reviewed. The specific applications and limitations of these methods are examined. In vitro assays are useful in providing information on heat damage in selected protein sources under defined conditions, and on relative ranking of different samples, but they cannot form the basis of practical feed formulations. While growth assays remain the only direct means of confirming nutritional relevance of values obtained by other procedures, in vivo digestibility assays appear to be most useful, at present, to estimate amino acid availability. Amino acid digestibility assays in poultry should be based on the analysis of digesta from the terminal ileum rather than excreta, because of the variable and modifying effects of hindgut microflora. Techniques used to estimate endogenous amino acid losses in poultry are discussed. The needs for correction of endogenous losses in amino acid digestibility calculations and the relative merits of apparent and true digestible amino acid systems are still being debated. It is, however, clear that both digestible amino systems are superior to the total amino acid system currently employed to formulate practical diets. Digestible amino acid values are likely to form the basis of poultry feed formulations in the future. In particular, there is an urgent need for more precise information on the variation in digestible amino acid contents of locally grown ingredients and on the factors causing this variation (e.g. variety, location, season, agronomic practices, processing, etc.).
1999-01-01Publisher
CSIRO Publishing, PO Box 1139, Collingwood, Vic. 3066Licence
Faculty of Science, University of Sydney School of Veterinary ScienceCitation
Australian Journal of Agricultural Research, (1999), Vol.50, No.5, 889-908Share
