Digital Audio Systems: Final Project (2020)
Browse by
Recent Submissions
Application of Adaptive System to ECG Analysis: Noise Attenuation and ECG Detection
Published 2020-07-28ECG or electrocardiogram is a tool used to monitor the electrical activity of a heartbeat. However, the detectable signal is incredibly small, and an electrical noise could be relatively large. This means it is necessary ...Open AccessReport, Technical -
Creating a Convolution Reverberation Effect from Impulse Responses in Physical Spaces
Published 2020-06-24This paper gives detail to the implementation of convolution of an input signal with an impulse response recorded in a physical space in both the time and frequency domain in order to model a reverberation effect. The ...Open AccessReport, Technical -
Digital Audio Effects Processing: A look into dynamic range processing
Published 2020-06-19This paper outlines Digital audio effects processing design with a focus on dynamic range processing specifically designing dynamic range limiters inside of MATLAB, this paper gives a brief introduction into the world of ...Open AccessOther -
Analogue Tape Simulation in MATLAB
Published 2020-06-19Analogue tape recording is known for its warmth, low end punch and smooth saturation (Robjohns, 2010). This project aims to simulate some of the characteristics of analogue tape recording using digital signal processing ...Open AccessOther -
3-Band Tone Control / 7-Band Parametric Equalizer
Published 2020-06-11This paper outlines the design of 3-band tone control and 7-band parametric audio equalizers comprised of a cascade network of second order peak and shelf filters, along with their MATLAB code and App Designer implementations. ...Open AccessReport, Technical
