Quantifying the impact of respiratory-gated 4D CT acquisition on thoracic image quality: A digital phantom study.
Purpose: Prospective respiratory-gated 4D CT has been shown to reduce tumor image artifacts by up to 50% compared to conventional 4D CT. However, to date no studies have quantified the impact of gated 4D CT on normal lung tissue imaging, which is important in performing dose ...
See morePurpose: Prospective respiratory-gated 4D CT has been shown to reduce tumor image artifacts by up to 50% compared to conventional 4D CT. However, to date no studies have quantified the impact of gated 4D CT on normal lung tissue imaging, which is important in performing dose calculations based on accurate estimates of lung volume and structure. To determine the impact of gated 4D CT on thoracic image quality, we developed a novel simulation framework incorporating a realistic deformable digital phantom driven by patient tumor motion patterns. Based on this framework, we test the hypothesis that respiratory-gated 4D CT can significantly reduce lung imaging artifacts. Method: Our simulation framework synchronizes the 4D eXtended Cardiac Torso (XCAT) phantom with tumor motion data in a quasi real-time fashion, allowing simulation of three 4D CT acquisition modes featuring different levels of respiratory feedback: (i) “conventional” 4DCT that uses a constant imaging and couch-shift frequency, (ii) “beam paused” 4D CT that interrupts imaging to avoid oversampling at a given couch position and respiratory phase, and (iii) “respiratory-gated” 4DCT that triggers acquisition only when the respiratory motion fulfills phasespecific displacement gating windows based on pre-scan breathing data. Our framework generates a set of ground truth comparators, representing the average XCAT anatomy during beam-on for each of 10 respiratory phase bins. Based on this framework, we simulated conventional, beam-paused and respiratory-gated 4D-CT images using tumor motion patterns from seven lung cancer patients across 13 treatment fractions, with a simulated 5.5 cm3 40 spherical lesion. Normal lung tissue image quality was quantified by comparing simulated and ground truth images in terms of overall mean square error (MSE) intensity difference, threshold-based lung volume error and fractional false positive/false negative rates. Results: Averaged across all simulations and phase bins, respiratory-gating reduced overall thoracic MSE by 46% compared to conventional 4D CT (p ~ 10-1945 ). Gating leads to small but significant (p<0.02) reductions in lung volume errors (1.8% to 1.4%), false positives (4.0% to 2.6%) and false negatives (2.7% to 1.3%). These percentage reductions correspond to gating reducing image artifacts by 24-90 cm3 of lung tissue. Similar to earlier studies, gating reduced patient image dose by up to 22%, but with scan time increased by up to 135%. Beam paused 4D CT did not significantly impact normal lung tissue image quality, but did yield similar dose reductions as for respiratory-gating, without the added cost in scanning time. Conclusions: For a typical 6 L lung, respiratory-gated 4D CT can reduce image artifacts affecting up to 90 cm3 of normal lung tissue compared to conventional acquisition. This image improvement could have important implications for dose calculations based on 4D CT. Where image quality is less critical, beam paused 4D CT 55 is a simple strategy to reduce imaging dose without sacrificing acquisition time.
2015-01-01Publisher
Med Phys. 2015 Jan;42(1):324-34Share
