Bandpass Limiter
Recording, acousticalAuthor/s
Vyas, NeilAbstract
Bandpass Limiter is a limiter that has a bandpass filter included in its design. When an audio signal is input into the limiter, it band-passes the audio signal before it gets to the limiter stage. The Bandpass Limiter can process mono as well as stereo files and it gives the user an option to use it as a mastering limiter as well as a bandpass limiter, where the low cut and high cut frequencies are defined by the user. All the parameters of the limiter like limiter threshold, attack time and release time can be defined by the user.Bandpass Limiter is a limiter that has a bandpass filter included in its design. When an audio signal is input into the limiter, it band-passes the audio signal before it gets to the limiter stage. The Bandpass Limiter can process mono as well as stereo files and it gives the user an option to use it as a mastering limiter as well as a bandpass limiter, where the low cut and high cut frequencies are defined by the user. All the parameters of the limiter like limiter threshold, attack time and release time can be defined by the user.
2016-06-06Faculty/School
DESC9115: Digital Audio SystemsShare
