New Developments in Arbil Metadata Manager
PresentationAuthor/s
Withers, PeterAbstract
This talk will introduce Arbil which is a tool for managing metadata that describes research data, such as audio or video files, allowing research data files to be easily searched both before and after they are archived. Arbil has been developed at The Language Archive at MPIPL ...
See moreThis talk will introduce Arbil which is a tool for managing metadata that describes research data, such as audio or video files, allowing research data files to be easily searched both before and after they are archived. Arbil has been developed at The Language Archive at MPIPL (Author, 2012) and was originally designed for the DOBES community to replace the IMDI Editor. The core needs expressed by this group was viewing and editing the metadata when in the field and being able to edit more than one metadata file at once. Indeed, Arbil is fully functional offline, provides tabular editing, and for robustness stores only text metadata files. For moving metadata and associated resources into an LAT archive, the structure is exported from Arbil and then uploaded into LAMUS (Broeder et al., 2006). Arbil was originally designed to support IMDI metadata (Broeder and Wittenburg, 2006). This format has been in use for many years, and it covers most needs with a number of set fields, but also may confuse researchers and slow down the workflow with so many fields to fill in. This issue has been addressed by CLARIN (Va ́radi et al., 2008). CLARIN provides flexible metadata fields, allowing a custom profile to be designed for each project ¬ only the relevant metadata fields need to be offered to the end user, greatly simplifying the process of creating metadata. Arbil has now been updated to support both IMDI and Clarin metadata formats. Because of the flexible design of Arbil, some of its components such as the metadata table and tree have been utilised in KinOath Kinship Archiver (Author, 2011). This application builds on the core functions of Arbil, onto which it adds an XML database to provide fast searches. Also, a plugin layer has been introduced in KinOath which has been migrated back into Arbil. Another project that is in the prototype stage is a web based search similar to the search in Arbil. These changes are being combined together as a search plugin for Arbil which is in development that will allow much more powerful searches to be available without compromising the original design of the application. References Author. 2012. Metadata Management with Arbil. In Proceedings of the Eighth International Conference On Language Resources And Evaluation (LREC 2012) Satellite Workshops, pages 72–75. Istanbul. http://www.lrec¬conf.org/proceedings/lrec2012/workshops/11.LREC2012%20Metadata%20Proceedin gs.pdf Author. 2011. KinOath, Kinship Software Beta Stage of Development. Talk presented at Atelier d’initiation au traitement informatique de la parenté. salle 3, RdC, bât. Le France. 2011¬12¬16. D. Broeder and P. Wittenburg. 2006. The IMDI metadata framework, its current application and future direction. International Journal of Metadata, Semantics and Ontologies, 1(2), pages 119–132. T. Váradi, S. Krauwer, P. Wittenburg, M. Wynne, and K. Koskenniemi. 2008. Clarin: Common language resources and technology infrastructure. In Proceedings of the Sixth International Conference on Language Resources and Evaluation (LREC’08), pages 1244–1248, Marrakech. European Language Resources Association (ELRA). http://www.lrecconf.org/proceedings/lrec2008/pdf/317_paper.pdf. D. Broeder, A. Claus, F. Offenga, R. Skiba, P. Trilsbeek, and P. Wittenburg. 2006. LAMUS : the Language Archive Management and Upload System. In Proceedings of the Fifth International Conference on Language Resources and Evaluation (LREC’06), pages 2291–2294, Genoa. European Language Resources Association (ELRA). www.latmpi.eu/papers/papers 2006/lamuspaperfinal2.pdf
2013-01-01Licence
The TLA Language Archive, Max Planck Institute for PsycholinguisticsShare
