A Unified Multi-Modal Approach for 3D Referring Expression Segmentation
Zhou, KeshenAbstract
Generalised 3D Referring Expression Segmentation (3D-GRES) segments exact 3D objects described by free-form language, even when descriptions match multiple targets, single targets, or zero targets. Most existing methods rely solely on sparse, colour-poor point clouds, neglecting ...
See moreGeneralised 3D Referring Expression Segmentation (3D-GRES) segments exact 3D objects described by free-form language, even when descriptions match multiple targets, single targets, or zero targets. Most existing methods rely solely on sparse, colour-poor point clouds, neglecting the complementary semantics richness of multi-view RGB images. In this paper, we propose IS-RES, a unified multi-modal framework that integrates RGB images and point clouds for 3D-GRES. Specifically, IS-RES extracts the instance mask by Segment Anything Model(SAM), obtains both dense and instance-aware 2D embeddings through CLIP, and unprojects 2D embeddings into 3D point clouds via confidence-weighted pixel-to-point association. A progressive multi-level fusion strategy is applied to transform fragmented multi-modal features into hierarchical representations, enabling adaptive alignment between instance-level semantics and geometric structures. Extensive experiments demonstrate that IS-RES achieves state-of-the-art performance on both ScanRefer and Multi3DRefer benchmarks, with significant improvements in challenging scenarios involving multiple instances and complex spatial relationships.
2025Licence
