Robust Lidar SLAM Under Adverse Weather
Cheng, QianAbstract
LiDAR Simultaneous Localization and Mapping (SLAM) technologies, which are the foundational technology of autonomous driving, have attracted large interest recently and been a significant research field. The performance of existing State-Of-The-Art LiDAR SLAM systems has been proven ...
See moreLiDAR Simultaneous Localization and Mapping (SLAM) technologies, which are the foundational technology of autonomous driving, have attracted large interest recently and been a significant research field. The performance of existing State-Of-The-Art LiDAR SLAM systems has been proven to produce accurate odometry estimation on autonomous driving datasets. These datasets are usually collected by vehicles equipped with various sensors under favorable weather conditions. However, challenging weather conditions such as rain and snow are still great obstacles because the rainfalls or snowflakes which are not static will cause noisy points for LiDAR perception and the assumption that the surrounding environment is static will be broken. Specifically, adverse weather will introduce noisy points which have physical structures and could be detected by LiDAR. Meanwhile, these noisy points would tightly surround the LiDAR and block other objects. This will lead to serious deficiencies in environmental structures and introduce more difficulties to pose estimation and loop closure, finally increasing the error of pose estimation and reducing the accuracy of LiDAR SLAM algorithms. Considering that noisy points usually lack the inherent structures exhibited in clean points, we propose a novel denoising framework for point clouds generated from lidar sensors that eliminate stochastic noisy points in a down sampling and super resolution manner to address this issue. Specifically, we first investigate to which degree the performance of the State-Of-The-Art lidar SLAM approaches will decrease when exposed to adverse weather conditions and then implement the denoising framework by combining the DS module with SR module which is based on the U-Net and trained under certain super-solution datasets. The accuracy and robustness of our framework were validated on the Oxford RobotCar dataset and the Canadian Adverse Driving Conditions dataset.
2023Licence
