Cerebral Metamorphopsia: Perceived spatial distortion from lesions of the adult human central visual pathway
Wan, Sue LinAbstract
Metamorphopsia is the perceived visual illusion of spatial distortion. Cerebral causes of metamorphopsia are much less common than retinal or ocular causes. Cerebral metamorphopsia can be caused by lesions along the central visual pathway or as a manifestation of epileptogenic ...
See moreMetamorphopsia is the perceived visual illusion of spatial distortion. Cerebral causes of metamorphopsia are much less common than retinal or ocular causes. Cerebral metamorphopsia can be caused by lesions along the central visual pathway or as a manifestation of epileptogenic discharges. Geometric visual distortions may result from structural lesions of the central visual pathway after reorganisation of the retinotopic representation in the cortex. Very few experimental investigations have been performed regarding cerebral metamorphopsia as it is often viewed as a clinical curiousity and analysis of the perceived distortion is difficult due to its subjective nature. Investigations have been undertaken to understand cortical plasticity as an explanation for visual filling-in. There has been much interest in cortical reorganisation after injuries to the peripheral and central visual pathway. Behavioural experiments aimed at quantifying the possible visual spatial distortion surrounding homonymous paracentral scotomas may be able to demonstrate cortical reorganisation after brain-damage and provide clues regarding the neural processes of visual perception. The aims of the thesis are: 1. To identify which cases of metamorphopsia, both published and unpublished, might be a consequence of cortical spatial reorganisation of retinotopic projections. 2. To investigate perceptual spatial distortion surrounding homonymous paracentral scotomas in adults with isolated unilateral injuries of the striate cortex. A review of the literature describing cases of cerebral metamorphopsia was performed. Metamorphopsia caused by retinal or ocular pathology, psychiatric conditions, drugs or medications were excluded. A retrospective case series of eight patients with metamorphopsia from a cerebral cause was performed in two clinical neurology practices specialising in vision disorders. Two cases who suffered from paracentral homonymous scotomas due to isolated unilateral primary visual cortex (V1) lesions were identified from a Neuro-ophthalmology practice. Neuropsychophysical experiments to investigate visual spatial perception surrounding their scotomas were developed and tested using MATLAB and Psychtoolbox. The use of the term 'metamorphopsia' was only in reference to cases in which contours or lines were experienced as distorted. In the published literature, few cases of cerebral metamorphopsia have been identified as being potentially due to cortical reorganisation. The main result is a statistically significant visual spatial distortion in the visual field surrounding a paracentral homonymous scotoma when compared to a normal control. There is also significant distortion of perception in the subjects' "unaffected" visual hemifield. After lesions of V1, visual perceptual spatial distortions may occur in the visual field surrounding homonymous paracentral scotomas. The spatial distortion may also occur in the normal hemifield possibly due to long-range cortical connections crossing to the other hemisphere through the corpus callosum. A collaborative approach across disciplines within vision science is required to further investigate the mechanisms responsible for perceptual visual illusions. Behavioural testing in brain-damaged cases remains important in developing theories of normal visual processing. New neuroimaging and neuroscience techniques could then test these theories, furthering our understanding of visual perception. An understanding of normal visual perception could allow future modification of neuronal processes to harness cortical reorganisation and potentially restore functional vision in humans with lesions of the central visual pathway.
2023Licence
Save Sight InstituteAwarding institution
