Generalised component method-based finite element analysis of steel frames (No. R969)
This report presents a new analysis approach that incorporates macro-element joint models based on the Generalised Component Method in the FE analysis of steel frame buildings. The new analysis approach is termed Generalised Component Method-based finite-element (GCM-FE) analysis. ...
See moreThis report presents a new analysis approach that incorporates macro-element joint models based on the Generalised Component Method in the FE analysis of steel frame buildings. The new analysis approach is termed Generalised Component Method-based finite-element (GCM-FE) analysis. The fundamental aspects and principles of the GCM-FE analysis approach are established in this report, including the framework of GCM-FE analysis, the constitutive models for the connection components and the implementation of GCM-FE analysis in commercial numerical software including an automatic modelling technique. The GCM-FE joint modelling method is first validated against the experimental results of three steel beam-to-column connection types, including the bolted moment end-plate connection, top-and-seat angle connection and web angle connection. GCM-FE analysis is subsequently performed on a two-storey four-bay irregular steel frame, showing apparent advantages over the traditional analysis methods which adopt simplified joint models. The GCM-FE analysis not only provides the ultimate resistance and failure mode of the frame, but also accurately predicts the load-redistribution process inside the connections and the resultant effect on the structural framework.
2021Publisher
