Sequence learning using deep neural networks with flexibility and interpretability
Li, ChangAbstract
Throughout this thesis, I investigate two long-standing yet rarely explored sequence learning challenges under the Probabilistic Graphical Models (PGMs) framework: learning multi-timescale representations on a single sequence and learning higher-order dynamics between multi-sequences. ...
See moreThroughout this thesis, I investigate two long-standing yet rarely explored sequence learning challenges under the Probabilistic Graphical Models (PGMs) framework: learning multi-timescale representations on a single sequence and learning higher-order dynamics between multi-sequences. The first challenge is tackled with Hidden Markov Models (HMMs), a type of directed PGMs, under the reinforcement learning framework. I prove that the Semi-Markov Decision Problem (SMDP) formulated option framework [Sutton et al., 1999, Bacon et al., 2017, Zhang and Whiteson, 2019], one of the most promising Hierarchical Reinforcement Learning (HRL) frameworks, has a Markov Decision Problem (MDP) equivalence. Based on this equivalence, a simple yet effective Skill-Action (SA) architecture is proposed. Our empirical studies on challenging robot simulation environments demonstrate that SA significantly outperforms all baselines on both infinite horizon and transfer learning environments. Because of its exceptional scalability, SA gives rise to a large scale pre-training architecture in reinforcement learning. The second challenge is tackled with Markov Random Fields (MRFs), also known as undirected PGMs, under the supervised learning framework. I employ binary MRFs with weighted Lower Linear Envelope Potentials (LLEPs) to capture higher-order dependencies. I propose an exact inference algorithm under the graph-cuts framework and an efficient learning algorithm under the Latent Structural Support Vector Machines (LSSVMs) framework. In order to learn higher-order latent dynamics on time series, we layer multi-task recurrent neural networks (RNNs) on top of Markov random fields (MRFs). A sub-gradient algorithm is employed to perform end-to-end training. We conduct thorough empirical studies on three popular Chinese stock market indexes and the proposed method outperforms all baselines. To our best knowledge, the proposed technique is the first to investigate higher-order dynamics between stocks.
2021Rights statement
