Setting minimum clinical performance specifications for tests based on disease prevalence and minimum acceptable positive and negative predictive values: Practical considerations applied to COVID-19 testing
Ping Loh, TzeLord, Sarah J
Bell, Katy J.L.
Kathryn Bohn, Mary
Yee Lim, Chun
Markus, Corey
Fares Taie, Hernan
Adeli, Khosrow
Lippi, Giuseppe
Sandberg, Sverre
Horvath, Andrea
OBJECTIVES: Several guidelines for the evaluation of laboratory tests for severe acute respiratory syndrome-coronavirus-2 (SARS-CoV-2) infection have recommended establishing an a priori definition of minimum clinical performance specifications before test selection and method ...
See moreOBJECTIVES: Several guidelines for the evaluation of laboratory tests for severe acute respiratory syndrome-coronavirus-2 (SARS-CoV-2) infection have recommended establishing an a priori definition of minimum clinical performance specifications before test selection and method evaluation. METHODS: Using positive (PPV) and negative predictive values (NPV), we constructed a spreadsheet tool for determining the minimum clinical specificity (conditional on NPV or PPV, sensitivity and prevalence) and minimum clinical sensitivity (conditional on NPV or PPV, specificity and prevalence) of tests. RESULTS: At a prevalence of 1%, there are no minimum sensitivity requirements to achieve a desired NPV of 60%-95% for a given clinical specificity above 20%. It is not possible to achieve 60-95% PPV even with 100% clinical sensitivity, except when the clinical specificity is near 100%. The opposite trend is seen in high prevalence settings (60%), where a relatively low minimum clinical sensitivity is required to achieve a desired PPV for a given clinical specificity, and a higher minimum clinical specificity is required to achieve a desired NPV for a given clinical sensitivity. DISCUSSION: The selection of laboratory tests and the testing strategy for SARS-CoV-2 involves delicate trade-offs between NPV and PPV based on prevalence and clinical sensitivity and clinical specificity. Practitioners and health authorities should carefully consider the clinical scenarios under which the test result will be used and select the most appropriate testing strategy that fulfils the a priori defined clinical performance specification.
2021Licence
Faculty of Medicine and HealthShare
Licence
