Bifurcation of Locally Buckled Point Symmetric Columns-Experimental investigations (No. R867)
Report, ResearchAuthor/s
Rasmussen, Kim J.R.Abstract
The bifurcation equations for locally buckled point symmetric sections are derived in a companion report [1]. In the present report, two series of experiments are reported, one on narrow flange Z-sections and one on wide flange Z-sections. The main objective of the tests was to ...
See moreThe bifurcation equations for locally buckled point symmetric sections are derived in a companion report [1]. In the present report, two series of experiments are reported, one on narrow flange Z-sections and one on wide flange Z-sections. The main objective of the tests was to validate the bifurcation load predictions derived in [1] against experimental values. A further objective of the tests on narrow flange sections was to investigate the change in the direction of overall buckling, as predicted bu the theory, from principal axis direction to non-principal directions. A further objective of the tests on wide flange sections was to investigate the possible change of the critical overall buckling mode from a flexural mode to a torsional mode as a result of local buckling. Agreement is generally found between analytical and experimental results.
2006Publisher
