Experimental Investigation of the Distortional Buckling of Cold-Formed Stainless Steel Sections (No. R844)
This report describes the experimental investigation of cold-formed, thin-walled stainless steel sections subject to distortional buckling under compression. Austenitic 304, ferruruc 430 stainless steel and ferritic-like 3Cr12 chromium weldable steel sheets were brake-pressed into ...
See moreThis report describes the experimental investigation of cold-formed, thin-walled stainless steel sections subject to distortional buckling under compression. Austenitic 304, ferruruc 430 stainless steel and ferritic-like 3Cr12 chromium weldable steel sheets were brake-pressed into simple-lipped channels and lipped channels with low proportionality stress and low n-parameter, anisotropy and yield strength enhancements up to 2.33 times due to cold-forming. A total of 19 channel sections were tested and failed by distortional buckling at average ultimate stresses greater than the proportionality stress, and hence were influenced by material nonlinearity, with greater nonlinearity evident for sections with intermediate stiffener. This paper presents comprehensive procedures to determine stainless steel mechanical properties and procedures to investigate the distortional buckling mode of cold-formed section. Experimental data required to calibrate finite element models and assess current design guidelines for distortional buckling of stainless steel compression members are provided herein.
2005Publisher
