Bayesian Optimisation for Planning And Reinforcement Learning
Metadata
Show full item recordType
Morere, PhilippeAbstract
This thesis addresses the problem of achieving efficient non-myopic decision making by explicitly balancing exploration and exploitation. Decision making, both in planning and reinforcement learning (RL), enables agents or robots to complete tasks by acting on their environments. ...
See moreThis thesis addresses the problem of achieving efficient non-myopic decision making by explicitly balancing exploration and exploitation. Decision making, both in planning and reinforcement learning (RL), enables agents or robots to complete tasks by acting on their environments. Complexity arises when completing objectives requires sacrificing short-term performance in order to achieve better long-term performance. Decision making algorithms with this characteristic are known as non-myopic, and require long sequences of actions to be evaluated, thereby greatly increasing the search space size. Optimal behaviours need balance two key quantities: exploration and exploitation. Exploitation takes advantage of previously acquired information or high performing solutions, whereas exploration focuses on acquiring more informative data. The balance between these quantities is crucial in both RL and planning. This thesis brings the following contributions: Firstly, a reward function trading off exploration and exploitation of gradients for sequential planning is proposed. It is based on Bayesian optimisation (BO) and is combined to a non-myopic planner to achieve efficient spatial monitoring. Secondly, the algorithm is extended to continuous actions spaces, called continuous belief tree search (CBTS), and uses BO to dynamically sample actions within a tree search, balancing high-performing actions and novelty. Finally, the framework is extended to RL, for which a multi-objective methodology for explicit exploration and exploitation balance is proposed. The two objectives are modelled explicitly and balanced at a policy level, as in BO. This allows for online exploration strategies, as well as a data-efficient model-free RL algorithm achieving exploration by minimising the uncertainty of Q-values (EMU-Q). The proposed algorithms are evaluated on different simulated and real-world robotics problems, displaying superior performance in terms of sample efficiency and exploration.
2019-01-31Licence
Faculty/School
