http://hdl.handle.net/2123/685
Title: | Pathophysiology of normal pressure hydrocephalus |
Authors: | Owler, Brian Kenneth |
Keywords: | normal pressure hydrocephalus;cerebral blood flow;diffusion MR Imaging;Cerebrospiral fluid |
Issue Date: | 2004 |
Publisher: | University of Sydney. Surgery |
Abstract: | Normal pressure hydrocephalus (NPH), a CSF circulation disorder, is important as a reversible cause of gait and cognitive disturbance in an aging population. The inconsistent response to CSF shunting is usually attributed to difficulties in differential diagnosis or co-morbidity. Improving outcome depends on an increased understanding of the pathophysiology of NPH. Specifically, this thesis examines the contribution of, and inter-relationship between, the brain parenchyma and CSF circulation in the pathophysiology of NPH. Of the four core studies of the thesis, the first quantifies the characteristics of the CSF circulation and parenchyma in NPH using CSF infusion studies to measure the resistance to CSF absorption and brain compliance. The second study assesses cerebral blood flow (CBF) was using O15-labelled positron emission tomography (PET) with MR co-registration. By performing CSF infusion studies in the PET scanner, CBF at baseline CSF pressure and at a higher equilibrium pressure is measured. Regional changes and autoregulatory capacity are assessed. The final study examines the microstructural integrity of the parenchyma using MR diffusion tensor imaging. These studies confirm the importance of the inter-relationship of the brain parenchyma and CSF circulation. NPH symptomatology and its relationship to the observed regional CBF reductions in the basal ganglia and thalamus are discussed. Regional CBF reductions with increased CSF pressure and the implications for autoregulatory capacity in NPH are considered. The reduction in CBF when CSF was increased was most striking in the periventricular regions. In addition, periventricular structures demonstrated increased diffusivity and decreased anisotropy. The relationship between these changes and mechanisms such as transependymal CSF passage are reviewed. The findings of this thesis support a role of both the CSF circulation and the brain parenchyma in the pathophysiology of NPH. The results have implications for the approach to the management of patients with NPH. |
URI: | http://hdl.handle.net/2123/685 |
Rights and Permissions: | Copyright Owler, Brian Kenneth;http://www.library.usyd.edu.au/copyright.html |
Appears in Collections: | Sydney Digital Theses (Open Access)
This work is protected by Copyright. All rights reserved. Access to this work is provided for the purposes of personal research and study. Except where permitted under the Copyright Act 1968, this work must not be copied or communicated to others without the express permission of the copyright owner. Use the persistent URI in this record to enable others to access this work.
