Abstract: | Abstract Birth of offspring of a pre-determined sex using flow cytometrically sorted fresh spermatozoa was first achieved in rabbits by Johnson et al. (1989). Since then offspring have been produced using sex-sorted spermatozoa from several different species (reviewed by Johnson, 2000). Initially, efficiency of the sex-sorting technology was poor with only low numbers of spermatozoa sorted per hour. Thus, the offspring derived from flow cytometrically sorted spermatozoa were produced with the use of artificial reproductive technologies (ART) such as in vitro fertilisation (IVF) and culture (IVC), intracytoplasmic sperm injection (ICSI) and deep artificial insemination (AI) which facilitated low dose insemination of potentially compromised spermatozoa. More recently, the development of high-speed sorters (Johnson and Welch, 1999) has facilitated the production of offspring using conventional AI techniques with low dose inseminates (Seidel et al., 1999) and successful cryopreservation of sorted spermatozoa (Schenk et al., 1999; Johnson et al., 2000; Lindsey et al., 2002; Schenk and DeGrofft, 2003). Increased efficiency of sorting bull spermatozoa has evolved through significant instrumentation and biological developments which have enabled the commercialization of the sperm sexing technology in the dairy industry, although conception rates in cows after low dose AI with sexed frozen-thawed spermatozoa are still lower than after standard frozen semen AI (Seidel et al., 1999). Subsequently, over 20 000 calves of pre-determined sex have been produced from commercially available sex-sorted frozen-thawed bull spermatozoa (Seidel, 2003). However, similar developments have not been made in the sheep industry and were examined in this thesis. In this study, successful cryopreservation of sex-sorted ram spermatozoa and production of offspring of the pre-determined sex (X: 94.4 %; Y: 100 %) was achieved after low dose (2-4 x 106 total) insemination using conventional laparoscopic intrauterine (IU) AI. However, the overall pregnancy rate for ewes inseminated with sex-sorted frozen-thawed spermatozoa was low (25 %) compared to ewes inseminated with a commercial dose (140 x 106 total) of non-sorted frozen-thawed spermatozoa (54 %). Cryopreservation has been found to not only reduce the proportion of motile spermatozoa, but cause the remaining spermatozoa to undergo changes that advance membrane maturation thereby shortening their lifespan, especially after in vivo fertilisation (Gillan and Maxwell, 1999). It was found that sorting prior to cryopreservation accelerated the maturation of sperm membranes and after co-incubation with oviducal cells in vitro, sorted frozen-thawed spermatozoa were released more rapidly than non-sorted (control) frozen-thawed spermatozoa. The potentially reduced lifespan of sorted frozen-thawed spermatozoa, and practical constraints on the number of spermatozoa that can be sorted for an insemination dose, makes insemination close to the site of fertilisation and time of ovulation critical for successful fertilisation. After treatment of ewes with GnRH to increase the precision of insemination in respect to the time of ovulation, there was no difference in pregnancy rate between ewes inseminated before, during or after the assumed time of ovulation. Furthermore, there was no difference in pregnancy rate after IU AI with similar doses of sorted frozen-thawed and non-sorted frozen-thawed spermatozoa in GnRH-treated ewes. The minimum dose of sorted frozen-thawed spermatozoa required for commercially acceptable pregnancy rates determined after IU AI was high (20 x 106 motile). Consequently, alternative methods for efficiently producing large numbers of offspring of a pre-determined sex using flow cytometrically sorted ram spermatozoa were investigated. Ram spermatozoa can be stored for short periods of time in a chilled state (liquid storage) or for an indefinite period of time in a frozen state (frozen storage; Salamon and Maxwell, 2000). The fixed location of the sperm sorter requires the need for transport of semen from the point of collection to the site of sorting and processing, but also from the sperm sorter site to the recipient females under artificial conditions. In this study, ram spermatozoa liquid stored for 24 h prior to sorting were efficiently sorted, frozen, thawed and after in vitro fertilisation and culture produced a high proportion of grade 1 blastocysts. Similarly, spermatozoa stored at reduced temperatures after sorting maintained high sperm quality for up to 6 days. Furthermore, frozen-thawed spermatozoa from rams and some non-human primates were successfully prepared for sorting and efficiently sorted producing spermatozoa with high quality in vitro parameters. The quality of frozen-thawed ram spermatozoa after sorting was such that successful re-cryopreservation after sorting was possible. Low numbers of frozen-thawed sorted and re-frozen and thawed spermatozoa were optimal for IVF and a high proportion of grade 1 in vitro embryos of a pre-determined sex were produced. These embryos were either transferred immediately or vitrified prior to transfer, extending the application of the sperm sexing technology further. The birth of lambs of pre-determined sex after transfer of both fresh and vitrified embryos derived from frozen-thawed sorted spermatozoa was achieved. The findings in this thesis suggest that sorted frozen-thawed ram spermatozoa may have more advanced membrane maturation state than non-sorted frozen-thawed spermatozoa, resulting in a decreased fertilizing lifespan in the female reproductive tract. Despite this, the use of sexed ram spermatozoa in a number of physiological states (fresh, liquid, frozen) with several different ARTs is possible in producing significant numbers of offspring of a pre-determined sex. Improved efficiency in both sperm sexing and associated reproductive technologies is required for commercialization to be achieved in the sheep industry. |
