Effects of Water Deficit on Pollen Development in Rice
NGUYEN, Ngoc GiaoAbstract
Rice (Oryza sativa L.) is very susceptible to water deficit at any time during its life cycle as a semi-aquatic cereal crop. However, the consequential damage is particularly severe if water deficit occurs during reproductive phases. The conspicuous injury often observed in rice ...
See moreRice (Oryza sativa L.) is very susceptible to water deficit at any time during its life cycle as a semi-aquatic cereal crop. However, the consequential damage is particularly severe if water deficit occurs during reproductive phases. The conspicuous injury often observed in rice plants exposed to water stress during meiosis of the pollen mother cell is the reduction of grain set, which is attributed to the decline of male fertility. In spite of much research on drought-induced male sterility in rice, the underlying mechanisms of the problem are poorly understood. This project was therefore conducted to investigate the molecular mechanisms of water deficit-induced pollen sterility in rice. In this study three consecutive days of water deficit treatment at -0.5 MPa osmotic potential during anther development effectively reduced the leaf water potential (leaf) and the number of viable pollen which later led to a decrease in grain set. Moreover, this thesis demonstrates that the immediate deleterious effects of water deficit to plant fertility could be estimated using a young microspore viability index, which showed a strong correlation with mature viable pollen and grain set. The present work has also illustrated that oxidative stress appears to be a plausible cause for the decline of male fertility and grain set. Water deficit has induced the excessive production of reactive oxygen species (ROS) above the redox balance, which in turn caused detrimental effects to cellular DNA and might result in programmed cell death (PCD) in the anthers. Moreover, ROS accumulation effectively influenced ATP synthesis leading to a decrease in the level of ATP in the anthers. Excessive ROS accumulation after drought could be the consequence of insufficient activity of the antioxidant system, which has been illustrated by qRT-PCR expression analysis of major antioxidant genes. Down-regulation of those genes would increase the incidence of oxidative damage. In contrast, stable or up-regulated expression of these genes resulted in less oxidative damage. Detailed investigations of sugar metabolism in anthers has provided supplemental data to develop a model of sugar unloading and transport within anther using in situ hybridisation to mRNA techniques. Analysis of sugar transportation within the cellular compartments of anther has unveiled the role of sugar metabolism on pollen sterility in rice. qRT-PCR assays of genes associated with the sugar metabolic pathway has demonstrated that the supply of both sucrose and hexoses from the anther walls to the locules was not restricted after water deficit stress. The results indicate that water deficit might not cause sugar starvation for developing microspores as previously thought, nor inhibit the initial steps of sugar utilisation such as glycolysis. This thesis has suggested new ideas regarding the role of rising sugar levels to cope with oxidative stress in anthers. Sugar accumulation might have provided protection against oxidant damage by strengthening the antioxidant system. However, the interplay between sugar and oxidative stress is not straightforward and needs to be further characterised. In-depth investigations on the interaction between sugar signalling and oxidative stress responses may help indentify the role of sugars in protecting anthers under water deficit. Although many studies on drought and chilling stresses in rice anthers have been performed, the causal mechanism of male sterility still remains to be elucidated. Findings presented in this thesis may contribute to understanding molecular mechanisms of male sterility in rice as a response to drought stress. A more detailed investigation of mitochondrial respiration in rice anthers is required to further examine this problem. Finally, this thesis suggests that signalling molecules such as 14-3-3 proteins and abscisic acid (ABA) might act upstream of ROS production and antioxidant defence in plants. Further work on these molecules might therefore further illustrate how they influence plant fertility under water shortage conditions.
2008-09-07Licence
