Performance Analysis of Maximal-Ratio Combining and Space-Time Block Codes with Transmit Antenna Selection over Nakagami-m Fading Channels
Chi, ZhanjiangAbstract
The latest wireless communication techniques such as highspeed wireless internet application demand higher data rates and better quality of service (QoS). However, transmission reliability is still degraded by harsh propagation channels. Multiple-input multiple-output (MIMO) systems ...
See moreThe latest wireless communication techniques such as highspeed wireless internet application demand higher data rates and better quality of service (QoS). However, transmission reliability is still degraded by harsh propagation channels. Multiple-input multiple-output (MIMO) systems can increase the system capacity and improve transmission reliability. By transmitting multiple copies of data, a MIMO system can effectively combat the effects of fading. Due to the high hardware cost of a MIMO system, antenna selection techniques have been applied in MIMO system design to reduce the system complexity and cost. The Nakagami-m distribution has been considered for MIMO channel modeling since a wide range of fading channels, from severe to moderate, can be modeled by using Nakagami-m distribution. The Rayleigh distribution is a special case of the Nakagami-m distribution. In this thesis, we analyze the error performance of two MIMO schemes: maximal-ratio combining with transmit antenna selection (the TAS/MRC scheme) and space-time block codes with transmit antenna selection (the TAS/STBC scheme) over Nakagami-m fading channels. In the TAS/MRC scheme, one of multiple transmit antennas, which maximizes the total received signal-to-noise ratio (SNR), is selected for uncoded data transmission. First we use a moment generating function based (MGF-based) approach to derive the bit error rate (BER) expressions for binary phase shift keying (BPSK), the symbol error rate (SER) expressions for M-ray phase shift keying (MPSK) and M-ray quadrature amplitude modulation (MQAM) of the TAS/MRC scheme over Nakagami-m fading channels with arbitrary and integer fading parameters m. The asymptotic performance is also investigated. It is revealed that the asymptotic diversity order is equal to the product of the Nakagami fading parameter m, the number of transmit antenna Lt and the number of receive antenna Lr as if all transmit antenna were used. Then a Gaussian Q-functions approach is used to investigate the error performance of the TAS/STBC scheme over Nakagami-m fading channels. In the TAS/STBC scheme, two transmit antennas, which maximize the output SNR, are selected for transmission. The exact and asymptotic BER expressions for BPSK are obtained for the TAS/STBC schemes with three and four transmit antennas. It is shown that the TAS/STBC scheme can provide a full diversity order of mLtLr.
2007-09-01Licence
